Soldering temp
mkane · 3598
Offline mkane
on: February 05, 2015, 05:29:50 AM
  Just bought a Hakko. Need advise on temperature setting. Default setting is 750 f. Seems hot.
Reply #1 on: February 05, 2015, 05:48:12 AM
Sounds a bit, i have the default temp on mine set to 350c, sometimes i bump upto 400c if there is a large heatsink soaking up the heat.  Think that translates to around 650f and 750f.
Offline mkane
Reply #2 on: February 05, 2015, 06:45:32 AM
Thank you.
Reply #3 on: February 05, 2015, 07:19:37 AM
In the office, we solder with the temperature all the way up.
(For soldering LED's, having the temp this high means you need just a second or two of iron contact)
Offline mkane
Reply #4 on: February 05, 2015, 08:00:41 AM
  thx again
