Will a 6.5mv Goldring 1042 potentially overload a Seduction with C4S?
vynyltap · 20998
Offline vynyltap
Subject pretty much says it all - will I have any chance of overloading the Seduction / C4S combo with a Goldring 1042?
I heard one of these cartridges recently and was quite impressed.
Online Paul Birkeland
I have a Rega cartridge at 6.8mv that has been just fine with 3 Seductions, an Eros, and the Tube Phono.
Offline debk
 I using a Goldring 1012GX (6.5mV ) with my Seduction and it sounds great.
Thinking of upgrading the stylus to the 1042
Debra
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite  300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
Seduction can take a midband input of around 200mV - few cartridges can generate that much!
Headroom across the frequency band gets pretty complicated, allowing for the RIAA equalization and recording limitations, which is why I just quote an approximate "midband" figure. The first stage can take nearly a volt. That would clip the second stage in the bass where the equalization does not attenuate much, but a velocity cartridge (i.e. any magnetic cart - moving magnet, moving iron, or moving coil) can't generate much voltage at low frequencies because the groove spacing is limited. You get the idea ...
Offline vynyltap
Thanks everyone - placed an order for one!
Offline debk
You will be very happy. I just ordered the 1042 stylus, will let you know what I think when I get it
Debra
Debra K
Eros 2Phono amp
Roon Nucleus
Jager speakers
