Modded Crack - add bypass cap, choke and Cree diodes
ALL212 · 164498
Offline Tom-s
Reply #45 on: October 19, 2016, 09:04:00 AM
Yes.
*And i don't see what could be done about it if there was. Other than better wind the wires. Shielding the heater wires...
Reply #46 on: October 19, 2016, 09:22:46 AM
The point is if you are seeing spikes anywhere you might want to change to a rectifier that puts out a smaller spike or no spike in the B+ supply. One could also try implementing an RRSF filter between the heater secondary and the tube sockets. This is tricky because you are pretty much limited to caps without any R or L, since they will add too much resistance to the circuit and the heater voltage won't be right.
This is why we went with the UF4007s. If the rectifier is quiet there is no spike that needs to be filtered.
Offline pingping
Reply #47 on: January 09, 2017, 01:44:46 PM
I know I'm a bit behind here in terms of the age of the thread, but I've just fitted the Cree based rectifier in my Crack, and can immediately recommend it.
Cheap, quick, and no doubt that it is now pulling more detail than I was hearing before. I can't really argue with hearing new things.
Offline AllanMarcus
  • Mainlining my way to bliss
    • My DIY Site
Reply #48 on: March 19, 2018, 09:22:28 AM
pardon my ignorance, but is there BOM for the parts needs for the Cree/schottky rectifier mod?
Any instructions too? I sort of get it from the pics for the cree/board, but I'm not sure about the Schottky diode.
This seems like an easy, inexpensive mod that I would like to try.
thanks.
This space for rent
Offline ALL212
Reply #49 on: March 19, 2018, 11:03:38 AM
This should be it.
http://www.partsconnexion.com/product26996.html
or Google "Discrete Bridge Rectifier PCB - TYPE 2 (TO-220 Radial Style),"
If they're out let me know - I bought a few extra the last time.
« Last Edit: March 19, 2018, 11:06:10 AM by ALL212 »
Aaron Luebke
Offline Leland Hankins
Reply #50 on: March 19, 2018, 01:16:10 PM
If you want to go all out, I thread the hole in each diode via a tap, and then screw a nylon bolt through each diode, spaced 1/4 " apart.
Offline AllanMarcus
    • My DIY Site
Reply #51 on: March 19, 2018, 01:48:26 PM
This should be it.
thanks. That's the board. What cree diodes are needed? And what Schottky diode is needed?
This space for rent
Offline ALL212
Reply #52 on: March 19, 2018, 02:32:58 PM
Slow down - do some research...
Cree is the brand name, shottkey is the component type.
http://www.partsconnexion.com/product7559.html
Disclaimer - any information supplied is what I used under my own guidance.  Your ability to loosen the magic smoke is entirely up to your own skill level.
You need to read through the thread all the way carefully.  Especially noting that if you install these wrong or are not careful in what you're doing you can shock yourself or destroy the components.
Aaron Luebke
Offline AllanMarcus
    • My DIY Site
Reply #53 on: March 19, 2018, 03:35:33 PM
Got it. I was schooled on Head-fo too. I'm a-learnin'. I've recently learned which way goes up on the tubes!
This space for rent
Offline AllanMarcus
    • My DIY Site
Reply #54 on: March 31, 2018, 11:15:03 AM
Ok. I got my board and diodes. I would just like to verify the next steps.
1) Remove the 4 rectifiers at 18,19,20, and 21.
2) Wire the board as show in the diagram below. I will probably just glue a nylon spacer to the bottom of the board and then to plate like shown earlier in this thread.
I assume the wires should be twisted to the board, also as shown in some of the earlier posted pictures.
Is this diagram correct?
https://cdn.head-fi.org/g/9937481_l.jpg
This space for rent
Reply #55 on: March 31, 2018, 01:05:30 PM
Looks good.
Offline AllanMarcus
    • My DIY Site
Reply #56 on: March 31, 2018, 04:18:56 PM
Looks good.
Thanks! Mod installed and crack working. I have no idea if it sounds better as I have no temporal comparison skills, but I'm going to believe is sounds better. Exactly $10 better  ;)
This space for rent
Reply #57 on: March 31, 2018, 05:10:57 PM
Maybe $9.95.
Offline m17xr2b
Reply #58 on: April 16, 2019, 12:08:58 AM
Curious to hear the different in diodes myself but the board is forever not available. I see they have an assembled one but it's not using schottky ones. Is it what I need? As a last resort I'll get it just for the board and replace the diodes.
https://www.partsconnexion.com/ASSEM-77727.html
Offline ALL212
Reply #59 on: April 16, 2019, 03:48:47 AM
I might have a spare or two.  Let me know if you still need one.
Aaron Luebke
