Seiden switch fit in speedball
pro_crip · 6051
Offline pro_crip
on: June 02, 2010, 01:03:42 PM
I saw a great 23 step stereo stepped attenuator at the hificollective and was wondering if it would fit in a crack with the speedball upgrade? The switch is 45x45x65 (mm) or thereabouts. I also assume I'd need the unbalanced stereo not the balanced stereo version. Thanks a bunch, The Simpsons are on.
Rich
Richard J Feldman
Tune down, smoke up
Offline GLF
Reply #1 on: June 02, 2010, 02:51:13 PM
Looks like that might fit. It would be pretty snug though. You might have to move the speedball board that is closest to the attenuator.
Andrew Krafthefer
Offline tdogzthmn
  • Industrial Designer
Reply #2 on: June 03, 2010, 07:40:14 PM
Offline pro_crip
Reply #3 on: June 04, 2010, 09:24:46 AM
That looks about right but I ran into a problem trying to order from them, 2 mono attenuators and 1 stereo attenuator. All populated with Takman carbon film resistors. So I just went ahead and ordered the custom goldpoints instead. Pcx has the Takman carbons at a buck apiece. Never mind the 15 buck AN tants. Thanks anyway.
Rich
Richard J Feldman
Tune down, smoke up
