1.25A fuse with bottlehead crack?
dortmunder13 · 1949
Offline dortmunder13
on: April 02, 2015, 06:49:51 AM
I managed to blow the fuse that came with my kit, and my local hardware store only had 1.25A fuses in stock. Is this safe to use or should I go to some other stores / mail order a 1A fuse?
Thanks a bunch for any help.
Reply #1 on: April 02, 2015, 08:49:51 AM
It's fine. But make sure you know why the fuse blew in the first place before you replace it and fire the amp back up.
Reply #2 on: April 02, 2015, 09:49:06 AM
Thanks! I'm pretty sure I know how I blew it. I passed my resistance checks, failed a voltage check, tried to fix it be reflowing a couple of solder points and replacing a wire, and went straight back to voltage checks without doing resistance checks first (oops!) - turns out there were some resistances that I messed up.
It passes all the resistance checks again but I couldn't check voltage after the fuse blew. Hopefully all is well now.
