Which pot to buy?
AllanMarcus · 3461
Offline AllanMarcus
  • Mainlining my way to bliss
    • My DIY Site
on: April 04, 2015, 05:44:52 PM
Seems like getting an upgraded pot for the crack is easiest before assembly. Can I get a little help on what to look for?
10Km 25K, 50K, 100K, 250K, 500K
what's that mean? What's recommended for the crack? Does the speedball upgrade make a difference with regards to pot selection?
Linear vs log? What's recommended?
"B" type. What's that?
Links to suggested pots is appreciated.
This space for rent
Reply #1 on: April 05, 2015, 02:57:01 AM
In the Crack layout the pot is all by itself.  It has lots of room.  So build stock then swap it.
I suggest staying with the stock value of 100k Ohms.  You do not want linear, it should be log or audio taper.
Speedball doesn't change anything about the pot.
Offline AllanMarcus
    • My DIY Site
Reply #2 on: April 05, 2015, 04:46:58 AM
Thanks for the advice. Looks like the speedball might impinge upon the space available for a pot, but it good to know it don't change any of the electric requirements.
This space for rent
Offline Nathan
Reply #3 on: April 05, 2015, 03:12:46 PM
I bought and installed a PEC 100k stereo audio taper pot. Not much bigger than the stock pot, fits fine with the Speedball, and it tracks and sounds very good.
Crack/Speedball & SEX 2.1/C4S
Offline AllanMarcus
    • My DIY Site
Reply #4 on: April 05, 2015, 04:09:32 PM
Thanks! Can you pleas post a link to it?
This space for rent
Offline Nathan
Reply #5 on: April 05, 2015, 04:22:20 PM
