Excellent, that's 0.05dB of difference between channels, which is difficult to measure, and impossibly hard to hear.
The next set of measurements should be done at terminals 6 and 10.
Since you have the shorting jack, these will both be 0V unless we take some action. If you can find a pair of toothpicks, you can pop them in under the spring contacts for the tip and ring on the jack, just to lift the short. Alternatively, if you have a 1/4" TRS to 1/8 TRS adapter plug, go ahead and plug that in to release the spring contacts.
I would not use a pair of headphones to break this connection, as we want the signal level high and we want the headphones themselves out of the equation.
