Need some help, fuse blows
jflorek · 7106
Offline jflorek
Reply #15 on: July 21, 2015, 04:37:03 PM
Tried it with the tubes installed.  Fuse (1A) does not blow.  Unfortunately, the tubes do not glow.
John
Reply #16 on: July 21, 2015, 06:05:46 PM
I'm seeing something here that happens fairly frequently on the forum. PB asked you to try just the 12AU7 and you responded that you tried something different, both tubes installed. I guess it happens because we are sometimes not precise about what we are suggesting (this long distance troubleshooting stuff is without a doubt tricky) or maybe suggestions get read in a hurry. If you can go back and try what he suggested - just the 12AU7 tube installed - it may offer some useful info.
Offline jflorek
Reply #17 on: July 23, 2015, 11:44:45 PM
Thanks for the clarification.  You are correct.  I read more into the answer than was there.  I will try with just the 12AU7 tube istalled and let you know results tomorrow.  Thanks again for the support.
John
Offline jflorek
Reply #18 on: July 24, 2015, 02:27:57 AM
Ok.  I tried with just the 12AU7.  No glow.  No voltage on the 6,7 and 9,10 pins/spades on the transformer.
John
Reply #19 on: July 31, 2015, 10:42:22 AM
Is the fuse still in-tact?
Offline jflorek
Reply #20 on: August 13, 2015, 12:55:30 AM
yes
John
Reply #21 on: August 13, 2015, 07:26:44 AM
Set your meter to AC voltage, then measure the AC voltage between power transformer terminals 1 and 2 with the amp plugged in and switched on.
Offline jflorek
Reply #22 on: August 18, 2015, 01:30:14 AM
Meter set to AC, reading across pins 1 and 2 about 107
John
Reply #23 on: August 18, 2015, 08:03:20 AM
Are you in Japan?
If you perform this same measurement and get no voltage between terminals 4 and 5 on the transformer, as well as terminals 9 and 10 on the transformer, then it's possible that you accidentally cut one of the wires that goes from terminals 1 or 2 on the transformer into the actual body of the transformer.
This can be repaired with a scrap of wire and some solder if this is the case.
