Shunt regulator voltage problem
Mid-Ranger · 6875
Offline Mid-Ranger
Reply #15 on: June 15, 2015, 02:01:19 PM
Getting a low reading on the 431 regulator on the side in question......could that be it?
Online Paul Birkeland
Reply #16 on: June 15, 2015, 08:06:18 PM
What's the reading you see?
Offline Mid-Ranger
Reply #17 on: June 15, 2015, 10:07:14 PM
The 2 outer legs show .825 resistance the middle leg measures .001
Offline Mid-Ranger
Reply #18 on: June 15, 2015, 10:13:08 PM
Just checked the other 431 and it measures differently.
I'm checking resistance with it still soldered in the board, should I remove it to check it properly?
And could a bad LM431 cause low voltage on one side?
Reply #19 on: June 16, 2015, 02:32:30 AM
Please check the voltage on each side of each 2.49K resistor.
Measuring resistance across a semiconductor won't really tell you anything unless it's completely shorted.
Offline Mid-Ranger
Reply #20 on: June 16, 2015, 05:18:29 AM
Ok I removed the board to get a pic of the bottom.
I will reflow the joints and reinstall the board and get the voltage reading, sorry I missed that in my zeal to get the board removed!  :P
I will reflow socket D as well while I have the board off.
Here is the pic of the back side of the shunt regulator pcb.
Charles
Offline Mid-Ranger
Reply #21 on: June 17, 2015, 08:56:07 AM
Success!
Both D6 and D1 are now a stable 223v.
Removing the pcb allowed me to find my mistake of not soldering the drain wires from the STP to the center pin of D.
Offline Mid-Ranger
Reply #22 on: June 18, 2015, 04:34:05 AM
Out of curiosity, one of the 220ohm resistors might have been shorting to a neighboring tube pin, could that have caused the voltage drop?
Reply #23 on: June 18, 2015, 06:01:01 AM
Hmm, maybe.  If this did occur, the 220 Ohm resistor would pop if it hit one of the pins, and on the other side the supply for the 431 regulator would be grounded out, but you'd have a 0 biased 12BH7 forced to cook off 23mA, which would give you about 100V out of the regulator.
