Shunt regulator voltage problem
Mid-Ranger · 6598
Offline Mid-Ranger
on: June 13, 2015, 03:09:47 PM
I checked the voltage with the 12BH7 installed, all LEDs light up and the tube glows, but the voltage goes from over 300 and then drops to 100......
Any thoughts on what this could be or what I should look for?
Reply #1 on: June 13, 2015, 08:52:25 PM
What do you see on each Kreg?  Can you post some photos of the board and its connections?
Offline Mid-Ranger
Reply #2 on: June 14, 2015, 03:05:49 AM
I get 4 for each kreg.... let me see if I can get some pics.
Offline Mid-Ranger
Reply #3 on: June 14, 2015, 03:15:24 AM
Pic
Offline Mid-Ranger
Reply #4 on: June 14, 2015, 08:16:14 AM
So can I go on with some of the rest of the build?
I hate to stop all progress.....
Offline Mid-Ranger
Reply #5 on: June 15, 2015, 04:11:00 AM
Ok like a noobie I forgot to check the other leg, so the wire from D7 measures 222v, it's the wire from D1 that drops to 100v.
Reply #6 on: June 15, 2015, 07:07:08 AM
D7 should be grounded to the board through a 220 Ohm resistor.  If D7 has appreciable voltage on it (more than 1V), either the resistor is broken, or there is a wiring error.
Do not proceed with the rest of the build until the regulated power supply is functioning.
Offline Mid-Ranger
Reply #7 on: June 15, 2015, 07:09:52 AM
Hi,
Sorry not D7, I meant the red wire from D6 has the proper voltage.
Offline Mid-Ranger
Reply #8 on: June 15, 2015, 07:11:50 AM
Could the tube be an issue?
Half of it not working?
Reply #9 on: June 15, 2015, 07:12:31 AM
Can you confirm that you have a 431 regulator on each side of the board and not an MPS4250A installed by accident.
Offline Mid-Ranger
Reply #10 on: June 15, 2015, 07:25:32 AM
Yep, 431 on both ends.
Reply #11 on: June 15, 2015, 08:04:43 AM
And 2N2907's in the middle? (not 2N2222's)
Offline Mid-Ranger
Reply #12 on: June 15, 2015, 08:18:11 AM
Yes, took me a while to finally be able to see the writing on the A side, but both are 2907.
Offline Mid-Ranger
Reply #13 on: June 15, 2015, 12:11:45 PM
Paul I have checked every single part on the shunt regulator board and confirmed them all.
Also went over the wiring for every tube pin on D socket.
I am attaching a closer pic of IB and I0.......could a solder bridge cause the voltage drop problem?
Charles
Reply #14 on: June 15, 2015, 01:54:18 PM
I don't see a solder bridge between IB and OB, so no issues there.
Can you snap some photos of the bottom of the board?
Also, can you carefully measure the voltage on each side of the 2.49K resistor on the offending side?
