Muffled sound after speedball upgrade
a1171622 · 1897
Offline a1171622
on: June 19, 2015, 04:01:03 PM
Hi all,
After upgrading to speedball, I noticed there was no sound at first, just popping sound but when I turned the volume all the way up I could hear very tiny sound coming from headphones.
I checked all the transitors in their correct positions, all the connections seem fine to me.
Another thing I noticed is that I used the normal big wire (with the crack) for all of speedball upgrade by mistake, but I don't think this is the cause of the problem, is it?
Here is my voltage test result:
1. 71
2. 230
3. 0
4. 230
5. 73
6. 0
7. 220
8. 0
9. 220
10.0
11. 0
12. 0
13. 236
14. 0
15. 230
16. 0
17. 0
18. 90
19. 85
20. 0
A1. 73
A2. 0
A3. 1.5
A4. 0
A5. 0
A6 - A9. n/a
B1 70
B2 230
B3 220
B4 73
B5 230
B6 220
B7 0
Really appreciate your help!
Cheers
Reply #1 on: June 19, 2015, 07:46:00 PM
I am very interested in seeing photos of your larger Speedball PCB.
I would strongly recommend not running the amp for too long.  If you truly have 200V at 7 and 9, something is quite wrong with the wiring, and needs to be addressed immediately.
Offline a1171622
Reply #2 on: June 20, 2015, 12:25:04 AM
Hi PB,
I rechecked wiring and discovered that I miswired to terminal 4 instead of terminal 3.
All the voltage reading is normal now except 19 is 83, 20 is 0
I could hear a loud pop sound once on starting up and then buzzing sound from the headphones.
I checked all the capacitors and seems fine. Is there anyway that I blown up sth else from last time?
Regards
Reply #3 on: June 20, 2015, 06:13:14 AM
Yikes.
Both the Speedball and Crack manuals that I have list no voltage for terminal 19.  They also both list 0V for 20.
Yes, you put 200+ V into the big Speedball PC board where it should have been grounded.  It's kind of hard to say what may have failed in the process.  I would at least order a new large PC board and associated parts.
