Bottlehead Kits
Legacy Kit Products
Paramount
Blown Resistor [resolved]
Bottle Rocket
5278
Bottle Rocket
Jr. Member
June 24, 2015, 12:31:03 PM
I checked all the resistances on my paramount and they were in range. So I plugged it in to power it up for the first time to check voltages and the 90.9 ohm 1/8W resistor (90R9) in position R1 on the Active Load PC board started smoking and blew. Triple checked all my connections which look correct. Any ideas what could have caused this? Could it be a faulty resistor?
Last Edit: October 02, 2015, 03:38:44 PM by Caucasian Blackplate
Paul Birkeland
Global Moderator
Hero Member
Re: Blown Resistor
Reply #1 on:
June 24, 2015, 12:36:42 PM
Quote from: Bottle Rocket on June 24, 2015, 12:31:03 PM
No, if the resistor was faulty, other parts would pop.
If 17 and 18 aren't soldered together well, components on the driver board will blow.
Also check for backwards capacitors and missing and/or miswired jumpers.
Bottle Rocket
Jr. Member
Re: Blown Resistor
Reply #2 on:
June 25, 2015, 09:05:53 AM
Looks like I did cross wires on 16 and 17. That must have been the culprit.
Paul Birkeland
Global Moderator
Hero Member
Re: Blown Resistor [resolved[
Reply #3 on:
June 25, 2015, 11:02:39 AM
If you switched where those wires connected, your best bet is going to be to contact replacement parts for a new soft start PC board and parts.
Bottlehead Kits
Legacy Kit Products
Paramount
