Nickel Pin vs Full
Paully · 2535
Offline Paully
on: July 08, 2015, 01:57:44 PM
Posted on Magnequest but didn't get any takers so I deleted it.  I would expect full nickel to be better of course, but I was just curious, how much of the benefits of full does nickel pin capture?  It seems I read some people actually prefer the pin to full, so again curious as to why that could be.  A nebulous question I imagine, but was wondering about it.
Reply #1 on: July 08, 2015, 04:46:38 PM
I don't think anybody has any good theory, but core materials are audibly different for sure.
To clarify first - there are two main grades of "nickel":
50% nickel will handle about 60% as much power, per pound, but has about half the distortion compared to grain-oriented silicon steel such as M6. It also has enough better permeability to improve small-signal linearity. It's what Mike uses in output transformers when he says "nickel".
80% nickel will handle a small fraction (1/5 to 1/10th) as much power per pound as M6, but has much lower distortion and much higher permeability. This makes it the preferred core for small-signal transformers, and nearly useless for drivers or outputs.
The third option is pinstripes, 50% or 80% nickel interleaved with M6. Compared to M6, and done right (I for one have no idea what "right" is in this case), it should have somewhat better small signal linearity with somewhat more limited large-signal performance, performing in between the two components.
« Last Edit: July 09, 2015, 06:13:46 AM by Paul Joppa »
Offline Paully
Reply #2 on: July 09, 2015, 02:20:42 AM
It was a more interesting answer than I had read up to now.  So thanks for the response Paul.
Offline Strikkflypilot
  • Shellac fiddler
Reply #3 on: July 09, 2015, 03:44:22 AM
I don't think anybody has any goo theory
I am sorry, couldn't help myself, there seems to exist such a theory:)
https://en.m.wikipedia.org/wiki/Grey_goo
Home system:
DAC: Schiit Gumby
Amp: Bottlehead Mainline
Phones: HD800S
Office:
Sources: Iphone/ Ipod
DAC: Dragonfly Red+Jtrbug
Phones: HD580,HD600 grilles
Reply #4 on: July 09, 2015, 12:22:40 PM
My SR-45 was built with the pinstripe BH-5 transformer. I also have a pair of EXO-45 in full nickle that I switch back and forth, with the same BCP-15 plate choke. The EXO seem to have a more delicate sound while the BH-5 speaks with a bit more authority. And with the 45, every little bit helps...John
