Jeb's Build
Jeb Jeb · 26933
0 Members and 4 Guests are viewing this topic.
Offline Jeb Jeb
Reply #105 on: July 30, 2015, 01:51:22 AM
Great - yes enjoy!
I'll wait and see what recommendation you are given and maybe I can skip straight to that solution at the same time that I install the Speedball.
James Barker,
UK
Reply #106 on: July 30, 2015, 02:32:48 AM
Jeb, your volume control action is Crack FAQ #3.  Check the sticky.  I prefer to use a greater range on the volume control as it allows me to set a more precise volume level.
Offline Jeb Jeb
Reply #107 on: July 30, 2015, 11:49:13 AM
Thank you Grainger - that makes sense and it sounds good to me to have more range.  I'll look into getting those resistors.  I've been looking on the forums but I guess I do have a quick questions:
- I'm not sure I will but If I did fancy replacing the volume pot while I'm at it does a pot with a different impedance effect the resistors needed as per Crack FAQ 3 ?
Thank you in advance.  Really enjoying the Crack and the hd650 clamping force is indeed letting-up with use!
Jeb.
James Barker,
UK
Offline JamieMcC
Reply #108 on: July 30, 2015, 09:30:59 PM
I went down the resistor route with my Crack and it works well. A little later on I decided to try fitting a stepped attenuator (100k valab ladder type) after a little use the range seemed greater and decided I didn't need the resistors any more and later removed them. They are easy to fit and try and just as quick and easy to remove.
Offline adydula
Reply #109 on: July 31, 2015, 06:11:29 AM
Hi Jamie...
I got a reply from PB to add 33K's in parallel with the 33Ks already installed.
I listened for several hours yesterday and for some reason it seems back to ok for me??? Strange...
I know source material hasa a replay gain factor and if I listen to stuff with a lower or positve replay gain I have more than enough volume control rotation...as the gain goes high in the negative direction I dont have to turn up the volume much like not past 9oclock...
So maybe after this I will just leave it as is for a few weeks and listen and then decide to leave it as is, add or pull out what I already have.
Alex
Offline Jeb Jeb
Reply #110 on: July 31, 2015, 10:52:37 AM
Cool - Jamie, Alex -  i'll look to adding some of those resistors at the same time as speed ball and maybe a different volume pot down the line!
Since I'm so new to this going to keep it stock + speedball first and make sure I can get all of that working first as suggested.
But...having said that I do like to plan ahead so if I did want to try cap upgrades down the line will I curse myself later on if I don't think about it now  by figuring out some mounting options + holes and putting the stock output capacitors on fly leads to make it easier for myself later, or is it all easily do-able later on?  It looks like some of those terminals might be difficult to get to post speedball.
Also Jamie - would you have any personal recommendations for caps that are not overly big, easy to fit, available in the UK and you feel offer a nice improvement?.  I don't mind spending a bit - I think the Crack will take pride of place for the foreseeable!
James Barker,
UK
Offline JamieMcC
Reply #111 on: August 01, 2015, 12:12:46 PM
PMed you
Offline Jeb Jeb
Reply #112 on: August 02, 2015, 01:39:43 AM
Hi guys - bear with me - need to ask a couple of real noob questions about doing the Crack FAQ No.3 resistance modification:
1) never bought resistors before , so many types, prices etc -  just these ones will be okay and consistent with the quality of everything else? - http://www.maplin.co.uk/p/metal-film-06w-33k-ohm-resistor-m33k
2) so looking at the sketch of the pot I attached I understand I attach 1 x 75k resistor between the red wire and pot lug A  and  1 x 75k resistor between the white wire and pot lug B.   But I'm confused about which lugs the 33k resistors go between? One between lugs A and E,  one between lugs B and F ?
Sorry this is probably quite lame but I guess I'm not very good without pictures.  :-\  Thanks!   :)
Jeb
James Barker,
UK
Offline Chris65
Reply #113 on: August 02, 2015, 02:57:57 AM
Those resistors are fine (if a bit expensive, normally you can get them for very little).
Not sure which way you've drawn the pot, but if that's looking at it from the RCA jack side, then yes that's correct.
Just to confirm: the 75k resistors go between the wires that come from the RCA jacks & go to the outer lugs of the volume pot: one for red, one for white. You can add these at the RCA jack end or at the volume pot end.
The 33k resistors go between the outer lugs of the volume (not the centre lugs), top & bottom. That is, the lugs where the red & white wires from the RCA jacks connect & ground, the 2 lugs with the black wires attached (closest to the 12AU7).
« Last Edit: August 02, 2015, 03:04:43 AM by Chris65 »
Reply #114 on: August 02, 2015, 04:15:27 AM
I'm not sure I got the Mouser UK site, although I clicked on that link.  Here is my search.  I believe you have the right type and power rating (very low) you need.
http://www.mouser.com/Passive-Components/Resistors/Film-Resistors/_/N-7gz3w?P=1yzekiaZ1z0z819Z1yzaok0
Offline Jeb Jeb
Reply #115 on: August 02, 2015, 04:28:27 AM
Thanks Chris - I should have just used a photo! I have attached one to this message just to be a bit clearer but I think I have understood you correctly.
1 x 75K between Red RCA wire and A
1 X 75K between White RCA wire and B
1 x 33k between A & E
1 x 33k between B and F.
when I first read the FAQ somehow I got confused.  I am still learning my way as to the "why" of everything.
May I ask in very basic terms why it is necessary to have these 33K resistors going to ground as well as the 75k ones on the red and white cables?
PS. Grainger thanks for info about resistors I'll grab a few.   When I first did an online search some exotic ones were going for 4 or £5 each or more...  Some metal film, some carbon.  I guess these are "audiophile" resistors? the descriptions often talked about them having a certain "sound" be it warm or transparent or "dry".  I guess things like this are considered pretty dubious or else just not critical in this application.
James Barker,
UK
Offline adydula
Reply #116 on: August 02, 2015, 05:59:00 AM
Jeb......I asked the same question in another thread here are the resistors I used...very cheap and metal film from www.mouser.com
http://bottlehead.com/smf/index.php?topic=8151.0
Mouser #:   71-RL20S-G-33K
Mfr. #:   RL20S333GB14
Desc.:   Metal Film Resistors - Through Hole1/2watt 33Kohms 2%
2   $0.32   $0.64
Mouser #:   594-SFR16S0007502FR5
Mfr. #:   SFR16S0007502FR500
Desc.:   Metal Film Resistors - Through Hole1/2watt 75Kohms 1%
Here is a pix of them before I cleaned them up to test:
Alex
« Last Edit: August 02, 2015, 06:03:53 AM by adydula »
Offline Jeb Jeb
Reply #117 on: August 02, 2015, 07:04:26 AM
Cheers - thanks for the thread link -  I didn't realise all this had already happened in a parallel universe...  :) I need to be better with the search function!  in your pic Is there a reason why the resistors going across the middles are much bigger than the other ones even though they are 33k and the others are 75k ?
Alex You build looks nice and shiny and clean!!!... and with the speedball just tempting coming into view in the corner!
 It's great to see a picture, it really helps - that's why the bottlehead manual is so good I think.  While I wait for things to arrive I was watching some vids on soldering and I was wondering about what is the accepted method of joining a resistor to a piece of wire  - from your pic it looks like you create a loop or hook on the wire end and then you can wrap the resistor lead around it as if it were a terminal, then just join to the volume terminal as normal.
the heatshrink suggested on your thread is a good idea too - I will get some.
James Barker,
UK
Offline adydula
Reply #118 on: August 02, 2015, 09:33:34 AM
Hi Jeb...
There is no apparent reason as to why the resistors are different sizes that are apparent to me.
That said, both are rated at 1/2 watt more than whats needed and I chose tolerances of 1% and 2%, I couldnt find both at the same tolerance.
This may be why they are different physical sizes.
You can tack solder them on the pot terminals or try to wrap them around the terminals and solder but the joint is getting large here...
I have no issues with "tack" soldering if done well....there isnt any movement or strain on them.
One side of the pot outer terminals are already joined together so you could twist the 33ks together and solder to the inner most top terminal then each of the other leads of them
to the top and bottom outer pot terminal.
I elected to put the smaller 75 K resistors near the pot and away from the RCA jacks...read somewhere that this was the preferred method.
To neaten it up you can use heatshrink, solder the leads inline with the wire and attach and solder to a terminal and then slide the heatshrink over once cooled and shrink to make a
nice neat installation.
If u do use heatshrink, remember to put it on before you solder!!! LOL done that before....
I have done a lot of listening.....my wife thinks way too much!! Ha!!
The speedball kit makes things just a little nicer...
I dont think I am going to add the other resistors now as PB indicated I think that most of what I listen to is allowing me to go from 9 o'clock to 1 o'clock with plenty of enough
drive and volume...
So we are now a happy camper!!
Alex
Offline Jeb Jeb
Reply #119 on: August 02, 2015, 10:08:22 AM
A happy camper, pleased to hear it!  Those are great and welcome soldering tips, as ever, thank you.
I know what you mean about logging some serious listening time.  It's like I heard Doc say, it really does sound better when you build it yourself!
James Barker,
UK
