Cheers Alex!
I did just that - it was quite straightforward to expose a little area of the trace with a knife and it seems to have produced a good joint - from what I can tell at least! I was disappointed to mess up the pad but it's also good to learn a new technique if such a problem arises and to know there are ways around things with PCB work.
I'm quite pressed for time to devote to it at the moment but have finished the main board. Aiming to finish the others and get it wired in next week. I'm probably the slowest bottlehead builder yet...
One basic question for what's coming up in the manual - After assembly of the PCBs, when actually wiring the boards into the Crack circuit, the hook-up wire is passed through the holes from underneath the boards, so I presume that means you carefully solder the pads on the
top of the boards this time- correct? But using the same technique, pass the wire through, then bend it flat to the board to keep it in place, and be extra careful not to melt any nearby components?
I do like the PCB work so far- it's different and does require an extra degree of care and precision with the iron - but definitely satisfying and looks very cool. I'm sure it's pretty straightforward for you!
Hope you're still enjoying your amp too!
