signal path wiring
aragorn723 · 8976
Offline WK3K
  • Beginning to see the light...
Reply #15 on: August 23, 2015, 12:45:25 PM
Thanks for the quick replies! I guess a better question probably would have been what's the advantage of solid vs stranded wire?
W
Witold
Rega P3-24 w/ Rega Exact > Eros II> Quickie w/PJCCS > Stereomour II w/ DC filament supply > Blumenstein Orca Mini/Max 2.1
MacBook > Grace SDAC > Crack w/ Speedball > Sennheiser HD6XX
Reply #16 on: August 23, 2015, 02:04:06 PM
Solid is smaller than stranded of the same gauge.  It "forms" well and stranded can have strands can short from terminal to terminal.
Reply #17 on: August 24, 2015, 07:21:12 AM
Stranded is a pain to work with, and is really only useful if you will be subjecting the wire to mechanical stress, i.e. plugging and unplugging. If it's going to sit in one place, like inside an amp, use solid. It's easier to work with, solders better, doesn't have stray strands to poke out and screw things up.
Also, gauge is gauge, regardless of construction.
« Last Edit: August 24, 2015, 09:22:15 AM by fullheadofnothing »
Reply #18 on: August 24, 2015, 07:29:41 AM
I think Joshua misread my first sentence.
Klein and Ideal wire strippers have different places to strip solid and stranded wire.  It is because to keep the same current capability stranded has to be a larger diameter.  That makes it harder to poke into tube pins and terminals.
Reply #19 on: August 24, 2015, 09:27:17 AM
After some research, I see Grainger is right on this one. Stranded is calculated as equivalent cross section.
Offline Chris
Reply #20 on: August 24, 2015, 05:32:39 PM
Well, you DO call yourself "fullheadofnothing"....     ;)    just teasin' ya....
Reply #21 on: August 25, 2015, 01:06:33 AM
Well, Joshuah is right, gauge is gauge.  Gauge is the ampacity of the wire.  In stranded it takes a larger diameter because of the spacing of strands.
Offline Chris
Reply #22 on: August 25, 2015, 08:26:35 AM
Yeah, interesting.... I didnt know this until you 2 were discussing it.. Thanks
