Assembly question for Crack
Flux Capacitor · 1959
Offline Flux Capacitor
on: August 23, 2015, 09:14:44 AM
So I just finished putting together the regular Crack. When checking all the solder joints I noticed that B7L was not soldered. Checked through the manual to see if I missed a step but found it never said to solder B7L (B7U did get soldered though).
So my question is: Can I solder the black wire at B7L? Everything else is done.
Thanks for your time
Reply #1 on: August 23, 2015, 09:50:08 AM
Just checked all the resistances and got the expected values.
Looking at the solder joints again B8L and B7L are not soldered at the bottom wires. Should I just finish that solder and check values again?
Offline Deluk
Reply #2 on: August 23, 2015, 09:51:22 AM
B8 has a similar instruction. Where two wires are attached to the same terminal, soldering is done after the second wire is added. Some terminals have only one hole that has to be used for two wires but B7 and B8 have two holes. Convenient when fitting the wires and both are soldered on at the same time.
