Switched wires on 16u and 17u [resolved]
Bottle Rocket · 15960
Reply #15 on: September 10, 2015, 08:41:38 AM
Okay, got the power PC board out
Do you mean the board over the 9 pin socket, or the board on the power transformer?
Offline Bottle Rocket
Reply #16 on: September 10, 2015, 07:40:44 PM
I took out the board over the power transformer.  I think I misunderstood before.
You would indeed get zeros everywhere if you removed the power supply PC board. PB meant remove the driver PC board over the nine pin socket.
Well that certainly makes sense Doc that the readings would be 0.
I think I'll need a new power supply board at this point and then can see how things look.  (I've contacted replacement parts for a new one).
Reply #17 on: September 11, 2015, 05:07:42 AM
I think at this point, you should consider sending this amp in for the flat rate repair service.  If you do, please include all the parts that we have sent you (including any boards that may or may not be working).
Reply #18 on: September 11, 2015, 03:56:55 PM
I think I'll go ahead and do that.  Thanks.
Reply #19 on: October 02, 2015, 03:39:58 PM
I performed the repairs today on this amplifier.  The chain of zener diodes was indeed compromised and had to be replaced.
