Sobakasu · 2179
The values signified with a * are going to vary from ohmmeter to ohmmeter because these terminals are connected to the filter capacitors, which try to charge themselves off the battery in the meter, causing a fluctuating reading. If the circuit is connected properly these readings will wander in the tens or hundreds of Kohms or higher range. What you want to watch out for is a zero reading at one of these terminals, which would indicate that something is mis-wired.
Yes, I would proceed to voltage checks.
Maybe you forgot to put the fuse in?
