Voltage check and LED troubleshooting [resolved]
hifiDane · 3181
Offline hifiDane
on: September 16, 2015, 05:52:38 PM
Hey folks, I need some help. Resistance check passed but I am having some trouble with voltage check. I have gone through the manual and followed ever wire to make sure that it is in its proper location. I have checked every solder joint and re-heated and added a bit of solder to every joint.
Here are the terminals that aren't checking out for me on my voltage check:
2 - 90V (should be 170V)
4 - 90V (should be 170V)
7 - 6.4mV (should be 100V)
9 - 4.3mV (should be 100V)
13 - 90V (should be 170V)
15 - 245V (should be 185V)
B2 - 90V (should be 170V)
B3 - 6.1mV (should be 100V)
B5 - 90V (should be 170V)
B6 - 4.1mV (should be 100V)
Both tubes light up.
Neither of the LED lights turn on.
Also, I checked the AC on transformer and it was not reading the 150V value specified on the label but lower at 90V.
Thanks in advance!
« Last Edit: September 20, 2015, 03:47:58 PM by Caucasian Blackplate »
Reply #1 on: September 16, 2015, 07:27:40 PM
How are the resistances?
Just from cursory inspection, if the two leads that are in the red circle touch, you'll end up with a lot of problems.
What voltage do you get at terminal 2 with no tubes plugged into your Crack?
Offline hifiDane
Reply #2 on: September 17, 2015, 03:16:44 PM
Resistance checked out fine.
The two leads in the red circle are not touching.
I am reading 0.0V at terminal 2 without the tubes plugged in.
Reply #3 on: September 18, 2015, 12:27:35 PM
Check your fuse.
Offline hifiDane
Reply #4 on: September 18, 2015, 05:25:55 PM
The fuse appears to be just fine. (see attached photo)
I'm stumped at this point. From my observation, it appears that I have connected everything to its necessary location and that all my solder joints are sufficient enough for a sound connection. That being said, I'm a newbie when it comes to soldering so I can't say with authority as to whether they are sufficient or not. Does my soldering look decent? I'm sure it could be better but is there anything that stands out that I should fix or work on?
Let me know if I can take better or more specific pictures to help aid in assistance.
-Dane
Reply #5 on: September 18, 2015, 05:42:36 PM
These are extremely contradictory.  You have at least one very loose connection somewhere.  I would re-solder every joint on the amplifier.
Offline Strikkflypilot
  • Shellac fiddler
Reply #6 on: September 19, 2015, 06:51:54 AM
But reading how others do things is not always easy.
These original PACE trainee videos are the best videos I have ever seen. There are many about.
https://m.youtube.com/playlist?list=PL926EC0F1F93C1837
I watched these between my Crack and Mainline builds and they are different leagues entirely.
Home system:
DAC: Schiit Gumby
Amp: Bottlehead Mainline
Phones: HD800S
Office:
Sources: Iphone/ Ipod
DAC: Dragonfly Red+Jtrbug
Phones: HD580,HD600 grilles
Offline hifiDane
Reply #7 on: September 19, 2015, 03:17:55 PM
I'm going to go back over my build and re-check everything, again. I'll get a second set of eyes on it too.
I'll re-test resistance and voltage once I'm done checking my connections and post my results within the week.
Thanks.
Offline hifiDane
Reply #8 on: September 20, 2015, 12:45:42 PM
It works!!!!
I bet it was a bad solder joint that was giving me issues. Everything test out with flying colors and it sounds awesome.
Now onto making a custom walnut case for the amp. I'll post pictures once I have it complete.
Thanks everyone for the advice and suggestions.
-Dane
« Last Edit: September 20, 2015, 12:48:20 PM by hifiDane »
