Bottlehead Kits
Crack
6080/6AS7 sparking
6080/6AS7 sparking
jp.lichtenberg
1543
jp.lichtenberg
Newbie
6080/6AS7 sparking
October 05, 2015, 02:28:55 PM
Hello,
I built my crack several months back and have not had any issues until this week. Now, when I turn it on, I have a lot of sparking that happens in the 6080/6AS7 tube. What could be causing this issue?
JP Lichtenberg
Doc B.
Administrator
Hero Member
Re: 6080/6AS7 sparking
Reply #1 on:
October 05, 2015, 04:06:01 PM
it's most likely that the tube has developed an internal short. Try another 6080 and if that doesn't solve it do all your resistance measurements and report any values that are out of spec.
jp.lichtenberg
Newbie
Reply #2 on:
October 05, 2015, 04:31:10 PM
If it turns out to be an internal short, what can I do to prevent this in the future?
Paul Birkeland
Global Moderator
Hero Member
Reply #3 on:
October 06, 2015, 06:15:10 AM
Development of an internal short is often very random and very rare. You may never run into this again.
JamieMcC
Hero Member
Reply #4 on:
October 06, 2015, 09:02:35 PM
I had a 5998 once that would put on a good little firework show when it fired up with a handful of little sparks that would fly pinging around inside the tube. This display only happened when the tube was first powered on for a second or two then it would run fine. After about a week or so one channel went dead and the tube showed as having a short on my tester. I cant remember if this made a sound through the headphones or not but suspect I didn't have them plugged in when powering up which was my norm for powering up a new tube for the first time.
Bottlehead Kits
Crack
6080/6AS7 sparking
