Crack + Speedball. Everything was working for two days, fuse blown today
vlitzer · 2152
Offline vlitzer
I used my crack for months. Two days ago, I assembled the speedball, checked the voltages, and started listening since then, including a very long strech yesterday. Today, I turn it on, and the tubes are not glowing, checked the fuse and its blown.
Any ideas on Why?
Try a new 1A fuse, just to be sure that there is an issue.
If the amp blows a second fuse, let us know and we can point you in some different directions.
Offline vlitzer
Replaced the fuse with a 1 amp one, and it seems to be working now (couple of minutes on).
I understand that 0.5 Amp is a pretty low fuse, but I was just wondering, could be something wrong or its expected to get blown fuses from time to time?
Offline vlitzer
Right, but I have been listening on the crack for months, and two days after I added the speedball!
We used to ship the Crack with a 0.5 amp slo-blo fuse, then later switched to a standard 1A fuse, as a lot of folks were having a tough time finding replacement slo-blo fuses (and those suckers went out of stock with alarming frequency).
If your amp is running on the 1A fuse, you have nothing to worry about.
Yeah, the thing about fuses ... most amps, SS or tube, will have a large inrush current before they settle down to the operating current. And fuses have a time constant, which is longer for the slow-blow types. Ideally you would match the time constants, but this is never really possible. The big problem is, that for the SAME FUSE RATING AND TYPE, different brands (or even production lots) will have different time constants. So the 0.5A slow blows that we had on hand were quite reliable, but then we got a new batch... took a long time to sort that out.
Offline vlitzer
That makes sense.
Thanks for the responses! Indeed it seems to be working just fine (been listening since I posted :))
