Something BIG is coming on Black Friday
Doc B. · 46592
Offline sl-15
Reply #30 on: January 13, 2016, 04:40:30 PM
That indeed is a very nice layout. Great work and congratulations to another kit. Could you tell me what the resistors are for that connect the speaker output to ground? Thanks.
« Last Edit: January 14, 2016, 04:25:39 AM by sl-15 »
Stefan Hampel
Reply #31 on: January 13, 2016, 11:28:46 PM
Nice layout, love the symmetry. I assume the OT-5's the largest output transformers to date?
Reply #32 on: January 14, 2016, 05:47:26 AM
That's something I suggested we experiment with a few years ago and liked. It's a balanced speaker output. Seems to tighten up the bass a bit in some situations.
Yes. They new plate chokes and OTs add quite a bit of bass power handing compared to previous models.
Offline drewh1
Reply #33 on: January 19, 2016, 07:37:21 PM
They are level trims for each channel.  They can easily be bypassed, or one could pretty easily install input transformers and change the input jacks to XLR's, but there are so many situations where you want 12-20dB of padding at the input of an amplifier that we have insisted on including them with the stock amp.
Are there any issues with bypassing the trims?  I am not using a pre-amp so likely do not need to pad.  Does it change the input impedence?
thanks
« Last Edit: January 20, 2016, 11:49:21 AM by Caucasian Blackplate »
Ayre QB-9 USB DAC
Kaiju
Stereoumour
Crack with Beyerdynamic T1
Reply #34 on: January 20, 2016, 11:49:56 AM
You can turn them all the way up, which is as effective as bypassing them.
