Right Channel Death
Colin · 2555
Offline Colin
on: December 27, 2015, 07:03:17 PM
Hi,
My crack got problem; right channel is death silence, when i upgrade the output cap with clarity px100. Because the size is too big so I make some holes to stand the caps(maybe the problem happen when i makes holes progress).
The resistance different from manual book is,
7 & 9 3.05Kohm
13.    max up to 5Kohm
Center rca pin 110Kohm
Anyone please help me.
Thank you,
Colin
Reply #1 on: December 28, 2015, 09:05:44 AM
What voltages do you have?
3.05K isn't appreciably different than 3K.
Terminal 13 is marked with a *, which means anything that's significantly above 0 is good.
110K isn't appreciably different than 100K.
Reply #2 on: December 28, 2015, 10:51:16 AM
Well, the obvious suggestion is that the part you changed may well be where the problem lies. I suggest looking at the solder connections of your new output capacitor.
Offline Colin
Reply #3 on: December 28, 2015, 06:25:48 PM
Thank you for the replies.
The voltage is (only the different) :
2. 150v
4. 150v
13. 150v
15. 170v
21. 190v
A1. 80v
B2. 155v
B4. 80v
B5. 155v
I have take back the stock caps but the problem not be solve. Maybe the issues happen when i make holes(the vibration effect from machine). And also re solder joint in the part/wire i put down when install caps. But still haven't find the problem.
So i take some pictures here, maybe can help. Any suggestion will very helpful.
Thank you.
« Last Edit: December 28, 2015, 06:53:31 PM by Colin »
Offline Rocketman248
Reply #4 on: December 28, 2015, 08:59:44 PM
Problems aside, that is one beautiful build!
Nick DeBrita
Yokosuka, Japan
Offline Colin
Reply #5 on: December 29, 2015, 04:21:24 PM
Thank you. Sadly has problem.  :(
Reply #6 on: December 29, 2015, 11:09:02 PM
Your problem is on the terminal strip below the 6080 socket, one set of output capacitors is wired incorrectly. Double check those connections from the manual.
Offline Colin
Reply #7 on: December 30, 2015, 03:49:25 AM
Thank you Mcandmar. Now the problem is gone. Looking for speedball upgrade on next.😊😊😀
