light hum on the crack
damnub · 2925
Offline damnub
on: January 03, 2016, 04:14:17 AM
hello,
So im finely done with my build and it was working perfect but after 30 min i got a light hum on the right side of my headphones, its lighter as the 120hz hum and it slowly gets louder. If i put the crack off it goes away very fast(so its not in the tubes?). it also doesnt get louder if i turn the volume knob(so it also isnt in the volume meter?). i read the manual and i tried inspecting and resoldering everything. i even braided the rca cabling tighter. i also tried moving it around to see if it went away.
id love any help or suggestions.
~damnub
« Last Edit: January 03, 2016, 04:48:05 AM by damnub »
Offline Tom-s
Reply #1 on: January 03, 2016, 05:54:40 AM
What headphone's are you using?
Offline damnub
Reply #2 on: January 03, 2016, 06:07:35 AM
sennheiser hd600's they are like a week old and there is no hum when i use it without the crack. so its probebly not the headphones
« Last Edit: January 03, 2016, 06:18:40 AM by damnub »
Reply #3 on: January 03, 2016, 06:40:50 AM
A light hum in only one ear could be a flaky solder joint, or it could be a tube that's just a little noisy.  Often times if you give the tubes 3-4 days of constant use, such noises will go away.
Offline damnub
Reply #4 on: January 03, 2016, 07:41:44 AM
Oh thanks man, ill resolder the joints and leave the amp on over for a few nights.
Offline damnub
Reply #5 on: January 14, 2016, 03:46:56 AM
hi im back again. and the hum is still not gone. I had the amp on for about 50 hours but probably more. I resoldered most of the solders. i also recorded the hum so mabye someone recognizes it. https://soundcloud.com/damnub/crack-hum . If auto play is on the next song will be super loud
id love any help I can get.
« Last Edit: January 15, 2016, 06:17:16 AM by damnub »
Reply #6 on: January 14, 2016, 11:44:42 AM
I'd be happy to have a listen to the track, but when I click on the link, it says that the track is private.
Offline damnub
Reply #7 on: January 14, 2016, 11:10:30 PM
whoops sorry, I fixed it now! its really subtle and its not the background grain.
Offline Deluk
Reply #8 on: January 15, 2016, 05:45:10 AM
Beware of Monstercat after the hum track finishes. might blow your eardrums.  >:(
Offline damnub
Reply #9 on: January 15, 2016, 06:16:44 AM
wow damn auto play x( i wonder why it chooses monstercat. ill edit the post
