Buzzing when I connect RCA inputs
amerk84 · 2220
Offline amerk84
on: January 12, 2016, 08:25:04 PM
I finished my Crack amp, check the resistances and voltages and they all check out fine. When I turn on the Crack with headphones plugged in it operates quietly even with the volume turned all the way up. When I connect RCA input a loud buzzing starts. (I have already gone through and re-soldered all the joints)
I noticed some interested things:
1) if I touch the base plate with my finger the buzzing is significantly quieter
2) if I connect my phono RCA cables, which have dedicated ground wires, to the Crack input and I touch the RCA ground wire to the Crack base plate the buzzing also is greatly reduced
I noticed in some other forum posts that people suggested moving the Crack around to different parts of the room. That did not help. Another suggestion was that I try shielded RCA cables. The phone RCA cables are shielded.
Another possibly significant observation is that when I play music it comes through my headphones very quiet (using HD-650's).
What is going on here and how do I fix it?
Reply #1 on: January 13, 2016, 06:54:57 AM
You mention phone and phono. Are you using these terms interchangeably, or are you testing separately with a phonograph and your phone (i.e. using a 1/8" -> RCA cable plugged into a cellular telephone)?
It sounds like you might have a ground loop. Plug everything into the same power strip and see if that fixes the problem.
Can you post pictures of your build?
« Last Edit: January 13, 2016, 07:14:25 AM by fullheadofnothing »
Reply #2 on: January 13, 2016, 07:51:51 AM
Is there anything plugged into the other end of these cables?
Offline amerk84
Reply #3 on: January 13, 2016, 03:11:13 PM
@fullheadofnothing: That was a typo. I meant phono RCA cables.
@fullheadofnothing and @Caucasian Blackplate: These cables are connected to my turntable, which is powered by the same power strip that the Crack is powered by.
Reply #4 on: January 13, 2016, 05:12:43 PM
Does your turntable have an RIAA preamp built into it?
