Wire Strippers for Teflon Insulated Wire
AudioDave · 4004
Offline AudioDave
on: January 18, 2016, 01:33:43 PM
I am having a heck of a time stripping the insulation off of the teflon insulated wire that comes with the Bottlehead kits so need to get a better pair of wire strippers.  At this point cost is no object!  Any recommendations?
Dave
Reply #1 on: January 18, 2016, 03:40:41 PM
I like the Ideal strippers, but often for the Teflon wire we use some cheapo "plier" style ones I bought a pile of years ago, when we gave an amp building class. Look like these:
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fwww.harborfreight.com%2Fmedia%2Fcatalog%2Fproduct%2Fcache%2F1%2Fimage%2F9df78eab33525d08d6e5fb8d27136e95%2Fi%2Fm%2Fimage_17561.jpg&hash=b287b540582cebc4616d22ffc269f7f2841a32d3)
Main thing is to get something that is sized so it will cut the Teflon but won't nick the wire right where the insulation gets cut. The cheapos are adjustable so you can get them set just right.
As for cost, here's a thread I found on stripper prices -
http://forums.anandtech.com/showthread.php?t=1639812
Offline corndog71
Reply #2 on: January 18, 2016, 04:55:20 PM
A small nail clipper works well on Teflon insulation.
Rob
Offline Adrian
Reply #3 on: January 18, 2016, 11:35:46 PM
Doc B.
Those in the picture are the ones I use.
Once you get the size adjusted just right and locked-in with the screw & nut they work great.
Adrian C.
Offline AudioDave
Reply #4 on: January 19, 2016, 02:05:31 AM
Thanks guys, much appreciated!
Dave
Offline Adrian
Reply #5 on: January 19, 2016, 11:36:03 PM
Just checked the link.
I'm an old man now and I've got to say that the cost of strippers has gone up from my younger days.
Adrian C.
Offline ToolGuyFred
Reply #6 on: January 20, 2016, 02:21:22 AM
Costly, but these work well for me: http://uk.rs-online.com/web/p/cable-strippers/0662721/
John
Amateur Audiophile and Backstreet Boffin.
Original Foreplay with C4S + Sweet Whispers
ParaSEX amps with MQ nickel-cored outputs
Factory-built Lowther Acousta 115s with silver-coiled DX3s, wired in DNM solid-core
KEF active sub (help for the last couple of octaves).
Bottlehead DAC on batteries.
Offline Wired
Reply #7 on: January 20, 2016, 07:23:10 AM
If cost is no object, you might want to look at thermal strippers. I've used both the PVC and PTFE versions from Patco and would recommend.
Rick
Rick
Offline Adrian
Reply #8 on: January 20, 2016, 02:44:44 PM
OK - I'll bite.
Has anyone else clicked on Doc B.'s link (http://forums.anandtech/showthread.php?t=1639812) and get sent to a forum discussion on the price of dancers/strippers?
Adrian C.
