Channel imbalance after padding pot
Jamus · 4810
Offline Jamus
Reply #15 on: February 03, 2016, 06:29:14 AM
Pot is cooked, huh? Sorry, couldn't resist.  :P
Would this be a worthwhile place to upgrade to something other than the stock part from BH?
« Last Edit: February 10, 2016, 02:02:02 PM by Caucasian Blackplate »
Rega Planar3/Elys2 - Eros - BeePre - Kaiju - Klipsch Forte I's
Marantz CD5005
Crack w/Speedball - Senn HD650
Offline Lee Hankins
Reply #16 on: February 03, 2016, 08:48:24 AM
Absolutely!!!!!!!!
Lee Hankins
"End of the Road"
Homer, Alaska
Offline Jamus
Reply #17 on: February 03, 2016, 09:38:52 AM
What would you recommend Lee?
Marantz CD5005
Online Paul Birkeland
Reply #18 on: February 03, 2016, 09:43:05 AM
No, if you've cooked the stock volume pot, most of the more expensive potentiometers are considerably more fragile.
Offline Jamus
Reply #19 on: February 03, 2016, 10:07:38 AM
The issue with this particular mod for me was that the bottom ground tab was difficult to reach for solder removal and without complete solder removal the terminal hole was a tight squeeze for the resistor.
I like to think I'd have more luck starting with a clean slate even if the pot is more delicate (says the guy who's already melted power switches on 2 builds)  :-[
Marantz CD5005
Offline Jamus
Reply #20 on: February 09, 2016, 04:22:53 AM
Just wanted to close the book on this in case anyone is interested. I swapped the pot with a Pec 100K ohm. This did require very minor drilling in the chassis plate to widen both the hole for the pot and the orientation tab. There is a lot of room around the terminals of this pot which made the job very smooth. I re-completed the original planned mod with the resistors to pad the pot. Everything works and sounds great. Thanks for everyone's help with this.
Marantz CD5005
