Newly installed PJCCS on 1.1 Quickie no left channel output
frank bare · 1677
Offline frank bare
Quickie working fine. Installed PJCCS. Found voltage check points on Side B of tube socket B5, B6 only .2volts. Right channel is fine.
Other measurement as per manual: 1A/1B 26 v, A6 20v, B6 .2v, A5 2.0v, B 5 .2v.
New D batteries...9v have 6 v each.
hmm. Did the usual rechecks, re-solders, swap tubes left to right etc...found on B side: MJE350 transistor a small fragment of metal wire, across the connector pins. Cleaned and rechecked, still no sound on left channel.
What's your guess? Shorted MJE350? Something else?
What I do hear from the one right channel is amazing...so now sleepless until I can get the left channel back.
Thanks for your support,
Bare
Reply #1 on: February 04, 2016, 07:28:29 PM
What DC voltage do you have between Kreg and +Reg on the offending side? (Black probe to Kreg, red probe to +reg)
The center leg of the MJE350 transistor is notoriously hard to solder.  Reheat it with your iron and give it 5-10 seconds of heat to ensure that the joint flows properly.
Offline frank bare
PB, Hey your super fast on your support... Means alot when your in the trenches out here. Here's latest:
Voltage reading on A Right: Kreg and +reg: 2-2.2v
   "                          B Left:   Kreg and +reg: 1.7V
Followed your orders. Resoldered the MJE 350 transistor. Rechecked wiring and re-soldered
Same findings. Unfortunately.
IA 26.8V
IB 26.5V
A6 19.9V
B6     .7v
A5   1.7v
B5     .7v
What would be next? replace the PJCCS board? I'm open for all suggestions...Thanks!
bare
