Quickie left channel cuts out when I install RCAs
frank bare · 1529
Offline frank bare
on: February 08, 2016, 05:02:00 AM
Status on Quickie 1.1 and non-working  PJCCS board...
I decided to pull the board, unable to get left channel to work, no voltage to left side.
Powered up Quickie, rechecked voltages (all in spec) this is what I found:
1. With RCAs installed on input #1, left and Right work great.
2. When I install second set of RCAs, on input #2...it cuts out the left channel.
Why is this? All voltages good/wiring/tubes/interconnect double checked.
Could explain why PJCCS left channel does not work? Any help with the experts out there?
-thanks
Bare
Online Paul Birkeland
Reply #1 on: February 12, 2016, 01:59:47 PM
Is there a difference between the cables that you're using?  Is there a solder bridge across one of the input jacks?
Generally this will not have any impact on the functionality of the PJCCS.
