Crack Speedball hpjun's trouble shooting thread [resolved]
hpjun · 10760
Offline hpjun
I messed up my install of the speedball, I have some waxy resin substance that is covering the connections of the board making a bridge (not sure if its conductive it came out of the soldier). I also am not sure if I installed the LED's right since I didn't install them upside down. Also I need more wire for the install. It was difficult before because my soldering iron was bad, now I have a good one.
What do you guys suggest I do?
« Last Edit: April 01, 2016, 01:29:22 PM by Caucasian Blackplate »
Jun
Reply #1 on: February 09, 2016, 09:19:25 AM
Looks like the center leg of the upper 2N2222A might need a touchup with the new iron. The flux residue doesn't look like anything to worry about. Touch up that transistor leg and anything else that might look shaky and try it again. If that doesn't work you might need to get those LEDs out and see which way they are facing.
Offline Natural Sound
Reply #2 on: February 09, 2016, 09:23:56 AM
The "waxy resin substance" is flux. It is non conductive. But if you want to clean it off, a little isopropyl alcohol, a q-tip and a bit of light scrubbing usually does the trick.
I have successfully removed the diodes from the board without damaging them. I use a pair of needle nose pliers to gently grasp the LED. The solder connections on the LED are close enough that you can arrange the soldering tip and heat both connections at the same time. Once the solder liquifies simply pull the LED out of the board. It takes a little practice but this technique works great. Just don't force it. Once enough heat is applied the LED will practically fall out. If you accidentally break them replacements are available here. http://bottlehead.com/product/hlmp-6000-leds/
EDIT: Doc B. Beat me to it.
« Last Edit: February 09, 2016, 09:31:37 AM by Natural Sound »
Offline hpjun
Reply #3 on: February 09, 2016, 12:48:12 PM
Alright I'll see what I can do to touch it up. I don't want to mess the stock crack until I get the speedball looking good first.
Jun
Offline hpjun
Reply #4 on: February 10, 2016, 09:51:47 PM
Removing the leds are tricky. I might just snip them off and order new leds. Is there a way to test the led direction from a multi meter? I have a lot of functions on my meter.
Jun
Reply #5 on: February 11, 2016, 08:49:02 AM
You can look at the silver banded end to easily determine directionality.
Offline hpjun
Reply #6 on: February 26, 2016, 11:35:14 AM
I remember when I installed the speedball it worked but it had channel imbalanced and sounded generally worse.
If the leds where incorrect there won't be sound right?
Jun
Reply #7 on: February 26, 2016, 11:37:32 AM
If the leds are installed incorrectly they won't light and the voltages will be off. It will sound bad or most likely not work at all on the channel that is wrong.
« Last Edit: February 26, 2016, 11:39:21 AM by Doc B. »
Offline hpjun
Reply #8 on: February 26, 2016, 11:47:11 AM
Well it's an hassle to reinstall the speedball just to check.
I already ordered 8 new leds I'll just pull them all off now and reinstall.
Jun
Offline hpjun
Reply #9 on: March 01, 2016, 01:03:26 PM
I didnt change any leds they where already correctly installed since they lit up.
Installed the speedball and did the Voltage check and the values came out with in range so i gave it a listening test. I turned the volume about half and I hear buzzing in the left driver and when i turn up a little more the right driver has the buzz too but at a lower volume. Then i noticed the buzz is quietly audiable without headphones plugged in it's coming from the power supply area or the caps.
My music sounded Ok, except for the buzz. My crack was quiet before the speedball.
1 77
2 181.3
3 0
4 181.3
5 81.8
6 0
7 107.1
8 0
9 110.6
10 0
11 0
12 0
13 181.1
14 0
15 199
19 85
20 0
21 217
A1 81.6
A2 0
A3 1.53
A4 0
A5 0
A6 76.7
A7 0
A8 1.53
A9 0
B1 76.8
B2 180.7
B3 106.6
B4 81.6
B5 180.4
B6 110
B7 0
B8 0
« Last Edit: March 01, 2016, 01:12:21 PM by hpjun »
Jun
Reply #10 on: March 01, 2016, 01:17:38 PM
It's quite time consuming to go through a list of voltages and try to determine which might be in or out of spec. If you could post only the voltage readings that are out of spec, the terminal it was taken at, and what the manual says it should be we can usually come up with some suggestions little more quickly.
Offline hpjun
Reply #11 on: March 01, 2016, 01:47:53 PM
2nd column is my measurements, 3rd column is the manual's measurements, 4th column is the difference in values, I also put in bold the big differences.
1   77   75   103%
2   181.3   170   107%
3   0   0
4   181.3   170   107%
5   81.8   75   109%
6   0   0
7   107.1   100   107%
8   0   0
9   110.6   100   111%
10   0   0
11   0   0
12   0   0
13   181.1   170   107%
14   0   0
15   199   185   108%
20   0   0
21   217   206   105%
A1   81.6   75   109%
A2   0   0
A3   1.53   1.56   98%
A4   0   0
A5   0   0
A6   76.7   75   102%
A7   0   0
A8   1.53   1.56   98%
A9   0   0
B1   76.8   75   102%
B2   180.7   170   106%
B3   106.6   100   107%
B4   81.6   75   109%
B5   180.4   170   106%
B6   110   100   110%
B7   0   0
B8   0   0
Jun
Offline hpjun
Reply #12 on: March 01, 2016, 05:49:29 PM
Also the voltages are not balanced from right and left channels. I had that problem before speedball too.
Jun
Reply #13 on: March 02, 2016, 06:04:29 AM
Those readings look like pretty typical variations from tube to tube, and they aren't really out of spec far enough to be a major concern. I think the best approach might be to go back over all of the new connections made from the PC boards to the tube sockets, since this noise seems to have appeared after those parts were installed. Buzzing usually indicates a ground connection that is not perfect. If you have some other tubes you might also try them to see if the noise goes away or changes in any way.
Offline hpjun
Reply #14 on: March 02, 2016, 06:55:33 AM
Ok and the buzz sounds like the same kind of buzz from power supply. It's faintly audiable without headphones plugged in. I was thinking it might be picking things from the vibrations? I will do another resistance check and go over any soldier connections that are different and go over the ground on the speedball.
This is my second speedball install and it had similar problems before left channel had a buzz as well.
Jun
