Bottlehead Kits
Crack
Little help: Speedball small board voltage errors
Mark Ferring
2540
Mark Ferring
Jr. Member
February 21, 2016, 05:02:46 AM
Been running the standard Crack for a month with no issues. Just started on the Speedball. Built the small circuit board and made it to the first set of voltage checks. The upper right LED did NOT light. Here are the voltages...
OA 150
1A 390
B-A/B 0
1B 390
OB 110
Appreciate any thoughts on my issue.
Mark
Mark Ferring
Jr. Member
Re: Little help: Speedball small board voltage errors
Reply #1 on:
February 21, 2016, 10:55:17 AM
If it helps. I took a few pictures.
fullheadofnothing
Global Moderator
Hero Member
A noble spirit embiggens the smallest man
Reply #2 on:
February 21, 2016, 11:02:19 AM
B side PN2907 is backwards.
Mark Ferring
Jr. Member
Reply #3 on:
February 21, 2016, 11:21:33 AM
Geez.......
Stupid mistake.....thanks for catching it.
Do you think this will cause the part to fail or can I just swap it around?
Mark Ferring
Jr. Member
Reply #4 on:
February 21, 2016, 12:25:55 PM
Well, I rotated the transistor and now all the LEDs on the small board are on.....a positive step!
However, my voltages are still as indicated above.
Anyone know what that means?
Mark Ferring
Jr. Member
Reply #5 on:
February 21, 2016, 12:26:49 PM
Actually, the voltages are slightly different...
OA 150
1A 380
B-A/B 0
1B 380
OB 150
fullheadofnothing
Global Moderator
Hero Member
Reply #6 on:
February 21, 2016, 04:18:14 PM
Are the LEDs on the 9-pin socket lighting?
Mark Ferring
Jr. Member
Reply #7 on:
February 21, 2016, 04:59:06 PM
Yep, the two on the nine pin are lighting.....as well as all four on the small circuit board.
Mark Ferring
Jr. Member
Reply #8 on:
February 21, 2016, 05:01:50 PM
BTW, I will be out most of tomorrow so won't be able to reply if there is any sage advice. Don't want to seem rude!
Paul Birkeland
Global Moderator
Hero Member
Reply #9 on:
March 10, 2016, 12:53:18 PM
If you have 380V at IA, you have a loose ground wire in the amplifier (black), as there isn't any way to get voltage that high in your amplifier (your meter is struggling to resolve the voltage because of a bad connection in the amplifier).
Bottlehead Kits
Crack
