My Kaiju Has Arrived!
ebag4 · 34501
Reply #45 on: April 12, 2016, 04:28:33 PM
We will work on getting an order page up tomorrow.
Offline ebag4
Reply #46 on: April 12, 2016, 05:00:43 PM
Thanks Doc.
Best,
Ed
GO CARDS!!!
Offline pduk
Reply #47 on: April 13, 2016, 12:00:12 AM
I'm interested in ordering the DC filament kit as well. I can't hear any hum from my listening position but I can if I move around the room (and change CDs!) which is sufficiently distracting to merit getting it. Will keep an eye on the products pages.
P.
Reply #48 on: April 13, 2016, 03:50:42 PM
Offline pduk
Reply #49 on: April 13, 2016, 08:48:33 PM
Excellent, thanks Doc - ordered!
Offline ebag4
Offline drewh1
Reply #51 on: April 16, 2016, 02:17:18 PM
gorgeous set up man! I am jealous.  I think you need to balance the whole system out with another Kaiju though  ;)
what ribbon tweeter are you using?  I am having my speakers upgraded with a Raal 70-20. (if the guy ever gets it done)
Can't wait to hear what you think of the Sophia's.
Ayre QB-9 USB DAC
Kaiju
Stereoumour
Crack with Beyerdynamic T1
Offline ebag4
Reply #52 on: April 16, 2016, 02:29:40 PM
Thanks Drew.  The tweeter is a B&G Neo3 PDR run in open baffle.  It is actually a planar driver, not a ribbon.  The speakers are the GR Research "Wedgies", they play from 200 Hz and up, the bass units are a pair of 12" servo subs in a "U" alignment per channel, each channel has it's own 350 watts servo amp.  These speakers are odd in that you can walk behind them and they sound the same, I really love them. Can't wait to hear them with the Royal Princess, they are scheduled to arrive Monday.
Best,
Ed
GO CARDS!!!
Offline ebag4
Reply #53 on: April 17, 2016, 12:52:27 PM
I should receive my Sophia Royal Princess 300Bs tomorrow (specs below).  Are there a series of measurements I should run after the tubes have run in for a few hours?  What specifically should be checked?
Ed
Royal Princessâ„¢ 300B
Nominal operating conditions and parameters:
Filament voltage
5,0 V *
Nominal filament current
1,2 A
Plate voltage
300 V
Grid voltage (AC filament)
61 V **
Grid voltage (DC filament)
58 V ***
Plate current (AC filament)
60 mA
Plate current (DC filament)
62,5 mA
Grid to plate transconductance
5700 Ω
Amplification factor
3.85
Grid current
0.05 µA
Plate resistance
700 Ω
Limiting Operation conditions for safe operation-nor simultaneous ratings:
Maximum plate voltage
450 V
Maximum plate dissipation
40 W
Maximum plate current of average tube for fixed grid bias
70 mA
Maximum plate current for manually adjusted grid or self-biasing circuit
100 mA
* - AC filament supply or DC filament supply.
** - AC filament supply is used. The grid and plate returns should be connected to a center tap on the secondary of the filament transformer.
*** - DC filament supply is used. The grid and platter returns are connected to the negative end of the filament.
Ed
GO CARDS!!!
Reply #54 on: April 17, 2016, 03:44:35 PM
Those specs are the standard 300B specs, so you should not need to make any special measurements.
If your power line voltage deviates from 120v by more than 5v, you can measure the voltage across the 300B filaments (pin 1 to pin 4) to confirm the correct filament voltage.
As far as I have found, Western Electric never made any spec for maximum deviation of the filament voltage. A range of +/-10% was however common in those days (late thirties to early fifties). A few special-purpose tubes might have had a +/-5% rating. EML specifies +/-4%. In Kaiju the tube is operated at a fairly conservative plate voltage and current, so there's no reason I know of for a tighter spec that 4-5%
Offline ebag4
Reply #55 on: April 17, 2016, 03:45:57 PM
Thanks PJ, much appreciated.
Best,
Ed
GO CARDS!!!
Offline ebag4
Reply #57 on: April 19, 2016, 04:02:56 AM
I received the Royal Princess tubes.  Right out of the box there was a noticeable reduction in hum from my speakers, enough that it is nearly negligible, I would say less that my Stereomour with the JJ 2a3.
These tubes were used previously, reportedly with less than 400 hours on them, I don't know when they were last used.  They did not blow me away (other than the low noise floor) initially so I let them play about 5 hours and listened again, much better, noticeably better than the EH but not a night and day difference.  I put on The High Kings "The Parting Glass", fantastic sound enveloping my room. Great tone.  I'll put a few more hours on them before passing judgement.
Best,
Ed
« Last Edit: April 19, 2016, 05:07:41 AM by ebag4 »
GO CARDS!!!
Offline ebag4
Reply #58 on: April 23, 2016, 07:05:42 AM
I noticed I was getting a sound that I can only describe as ringing, I'm not certain that is accurate, it was a slight bell sound following certain notes, this was not constant but noticeable.  I started looking at the system and noted that the amp was in close proximity to a 12" woofer on one of the speakers.  Moving the amp about 12" appears to have taken care of that issue, after several tracks I have not heard it again.  It is still close but apparently not too close any longer:
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fs20.postimg.org%2Ftpqcy0mzh%2Fimage.jpg&hash=0b3399380723f081e83a7c3004384f95caca4601)
Best,
Ed
« Last Edit: April 23, 2016, 07:07:15 AM by ebag4 »
GO CARDS!!!
Offline ebag4
Reply #59 on: June 24, 2016, 06:17:36 PM
Well, I have been running the amp for a while so I decided to add the DC filament supply to allow me to try other tubes I have been considering.  I recieved the DC filament kit, it went together fantastically like all the Bottlehead kits do.  I powered it up for a few songs to make certain it was working correctly, total silence from my speakers, very nice.  With the Clarity 10uF MR caps it's getting pretty cozy in there:
(https://s20.postimg.org/nazk8hwpl/IMG_20160624_223124083.jpg)
I also recieved my tubes today, so I pulled the EH 300Bs, and put the new tubes in:
(https://s20.postimg.org/eowanwkpl/IMG_20160624_232922899.jpg)
The infamous Elrog 300B, they are the best sounding tubes I have heard, and I have been listening to them for less than a hour.  PJ says the basic Kaiju design parameters appear to be nearly ideal for this tube, so I'm hopeful I get reasonable mileage out of these.
Vocals are incredible, great presence helping make this the best amp I have heard.
Best,
Ed
« Last Edit: June 24, 2016, 07:22:15 PM by ebag4 »
GO CARDS!!!
