first time build, everything went pretty clean but... [resolved]
xaanix · 4659
Offline xaanix
resistances checked out, no issues, all behaved exactly as described in the manual.
when i got to voltage checks, i see most voltages are correct, however some voltage are much higher than expected.  Here is my full list of voltage checks.
B1 78.3
B2 169
B3 101
B4 152 (manual lists 90)
B5 169.2
B6 152 (manual lists 100)
B7 0
B8 0
T1 78.3
T2 169.5
T3 0
T4 169.5
T5 153 (manual lists 75-90)
T6 0
T7 101
T8 0
T9 153 (manual lists 100)
T10 0
A1 153 (manual lists 90)
A2 0
A3 0
A4 0
A5 0
A6 78
A7 0
A9 0
12T 0
11 0
12 0
13 170
14 0
15 193
20 0
21 217
Seems like a chain of 'hot voltage' is running through the build but does it originate from the tube?  (both b4 and b6 are hotter than expected and would be ouptut directly from the power tube no?)
The led's seem to behave properly, the tubes do heat up and glow in what appears to be a normal way (but i'm a newb so what do i know).  Could this be tube variance?
Am i ok to plug in headphones?
I have 2 other questions related to this voltage testing:
It asks us to turn the volume all the way down.  Well, which direction is down?  (would like confirmation of this since it is not specified anywhere).
« Last Edit: April 28, 2016, 04:52:08 PM by Caucasian Blackplate »
Offline Chris65
Reply #1 on: April 12, 2016, 07:04:55 PM
Hi,
There are other voltages that are not correct apart from the ones in red. The guys from BH will help you out.
Don't use an amp that does not pass all the checks.
Turn the volume control to the left (anti-clockwise) all the way, that is minimum (if wired correctly) ;).
Reply #2 on: April 13, 2016, 11:44:29 AM
The big issue here is A1, which is creating the rest of your problems.
I will assume that this is a stock Crack with no Speedball, if that isn't the case, let me know.
A1 will be higher than it's supposed to be when half of the 12AU7 is not conducting properly.  This can happen from:
1.  Half the 12AU7 isn't being heated (do both halves of the 12AU7 glow?).  This problem happens when the solder joint at A4 and A5 isn't well flowed.
2.  The 22K resistor between T1 and T2 isn't well soldered.
3.  The LED at A3 is broken or not soldered properly.  You can jumper A3 to A8 if you find signs that this is the case, but I recommend working on the other options first.
4.  The wire connecting to A2 has a poor ground reference, which can be a bad solder joint on this wire, a missing ground jumper between the lugs on the volume pot with the black wires, etc.  (You can measure the DC voltage carefully at A2 and A3 and post those for more detailed information)
Offline xaanix
Reply #3 on: April 13, 2016, 03:46:17 PM
Thank you so much -- this feedback is tremendously helpful and very appreciated.
Yes i am using the stock crack.   I will attempt to resolder A3 which i suspect could be a problem based on something i observed while building and re-test A4 and A5 (although i dont expect an issue there).   The manual doesn't mention, but i assume i would want to remove the tube in socket A for this?  That tube was not easy to get in (i feared i was going to break it like an egg).
Regarding A3 -- I did notice that the led on A3 powering up initially ( and reproducably) when I plugged in the cord, but it would go dark after a bit.  I also believe i noticed one of the resistance checks fluctuate (I think in A3) as i was taking the measurement, probably a useful clue.   Another concern is that while heating the center peg, i may have touched the LED at for a moment or two.  Maybe i cooked the LED... (not sure why it would still light up initially though).
So you're saying on your bullet #3 below that i could just direct wire A3 to A8 -- and that produces a workable circuit?   The manual mentions these LED"s set the bias voltage, however i'm not really familiar with that concept.
« Last Edit: April 13, 2016, 06:14:03 PM by xaanix »
Offline xaanix
Reply #4 on: April 13, 2016, 06:17:00 PM
resoldered a few joints.  I did see a problem with  T18.
Unfortunately i'm still seeing this issue.
I tried measuring across T1 and T2 to see about the resistor there and see it measuring a bit above 22k ohms. I also find the outside RCA (white) jack center pin measuring at 106k ohms.  The red measures 98k ohms.
I have the following behavior:
upon energizing the circuit, both LEDS are initially off, then begin to glow faintly and then more strongly at the same time.  After about 6 seconds (upon further testing, this varies, sometimes the circuit stays working normally for a few minute) -- (and after reaching what appears to be full brightness, the A3 LED suddenly begins to flash for approximately 4-5 seconds, then eventually it goes dark and does not return.  After powering down I can power back up and this behavior repeats itself.
I didn't measure exhaustively the voltages but T5 is still showing 150 volts.   I'd like to get a reading of T5 while it powers up..   Will give that a shot and see if it is just suddenly shutting down..
« Last Edit: April 13, 2016, 08:05:11 PM by xaanix »
Offline xaanix
Reply #5 on: April 13, 2016, 08:03:48 PM
Resoldered joints on T1-T2, and the Center Pin for socket A.
It's definitely a busted connection somewhere.   If i tap on the T1-T5 bridge I can make the A3  LED flicker,  (the other LED stays solid) sometimes if the problem manifests tapping the baseplate or tapping the T1-T5 bridge, or tapping the T1-A5 wire will  it will return the entire circuit back to normal for a while. Tapping the T1-A5 connecting wire seems to have a stronger effect.   Wondering if the reason i had such trouble getting the tube in is that the pins for the socket werent aligned.   Thinking the connection into the tube from A5 might be flaky... it seems slanted.   Going to try to take the tube out tomorrow and see if i can look down into the sockets from above and figure out whats going on..
« Last Edit: April 14, 2016, 01:01:34 PM by xaanix »
Offline xaanix
Reply #6 on: April 13, 2016, 08:06:50 PM
I tested connection to A2, (resoldered this, and the other side)..  Looks good, tests good..   didn't seem to have an impact.
Offline corndog71
Reply #7 on: April 14, 2016, 03:10:18 AM
In my tube noob days I sometimes added too much solder to the socket pins and it would leach down to where the tube pins go and cause a bad connection.
Rob
Offline xaanix
Reply #8 on: April 14, 2016, 08:16:09 AM
Here are some pics of my solder points.
I'm still thinking the problem is with the socket or the tube, or possibly the LED at this point. (not sure why it would blink and then go out though).
Reply #9 on: April 14, 2016, 08:27:23 AM
While you have amp upside down - Carefully plug in the tubes and power cord and carefully power it up. Then take a plastic pen or other non-conductive tool and poke around the connections to the tube socket to see if you can reproduce the on-off behavior.
Offline xaanix
Reply #10 on: April 14, 2016, 08:50:34 AM
Sure Doc!
In case you're interested in seeing it -- here is movie i took last night of what was happening:
https://drive.google.com/open?id=0B9VdJs7a5ON_YjZIYXRYWVZ0Z1E
It doesn't show the response to banging/tapping, as i figured that out later.  I will do as you suggest however and report back my findings.
I'm willing to order a new socket/tube/and LED's to help test/isolate and then fix the issue.
« Last Edit: April 14, 2016, 08:55:32 AM by xaanix »
Reply #11 on: April 14, 2016, 02:35:28 PM
If jostling the amp makes the behavior come and go, then you have a loose connection.  The one that I see that looks the most flaky is the solder joint on the lower level of terminal 2.
Offline xaanix
Reply #12 on: April 15, 2016, 12:43:31 AM
Terminal 2L?  I thought that was one of the better looking ones.  :-\ What looks wrong with it?
Here's some pics of some of the other components.
Offline Deluk
Reply #13 on: April 15, 2016, 02:30:28 AM
Sorry to say that many joints there look to be "glued" on rather than having nicely flowed solder. Maybe this is old solder that has poor flux now. Can also be caused by a bad or dirty solder bit that's not properly tinned.
« Last Edit: April 15, 2016, 02:37:12 AM by Deluk »
Offline xaanix
Reply #14 on: April 15, 2016, 03:09:24 AM
You're right, this was certainly old solder (not even sure how old) and was done with an old iron which was not in the best shape.  I just ordered a weller soldering station for 90$ on amazon, as well as some solder wicks.  They should be here today and tomorrow.  Based on your post I'll order some solder too since it seems that's needed.
