Triad c7x choke problem [resolved]
alepoli · 2040
Offline alepoli
on: April 30, 2016, 06:43:29 AM
Hi all,
I installed Mundorf evo aluminum caps and everything sounded great. Then the next weekend I installed a Triad C7x choke. Here are the voltage readings:
1   85
2   180
3   0
4   180
5   85
6   -.01 (supposed to be 0)
7   113
8   0
9   111
10   -.01
11   0
12   0
13   180
14   0
15   200
20   0
21   220
(Sorry I did not measure the tube voltages, the speedball boards are in the way and I did not want to short anything.)
Everything seemed to check out however when I plugged in my headphones and let the music flow I noticed the amp was quieter than before, to reach the same volume I had to turn it up by an additional number or so (referring to the clock analogy) in order to get the same volume. Is this normal? Any ideas?
« Last Edit: May 01, 2016, 07:51:57 AM by Caucasian Blackplate »
Reply #1 on: April 30, 2016, 09:55:46 AM
Your voltages don't indicate any problems, and the choke did not cause this problem.
It's likely that you have a flaky solder joint that you have disturbed by installing the choke, and now you are more able to hear it.
Offline alepoli
Reply #2 on: April 30, 2016, 06:27:05 PM
That fixed it! Thanks!
