Resistor upgrades for Eros?
mwaller · 3744
Offline mwaller
on: May 12, 2016, 08:21:49 AM
I've read a number of posts indicating that various resistors can be replaced for improved sound.
Many people swear by the TX2352 resistors...
Which resistors are most critical to the sound, and what components are considered the best replacements?
Mik
Offline mwaller
Reply #1 on: May 13, 2016, 07:36:58 AM
I've read that the 47K input load resistor and 47K (2W) output tube plate load resistor are critical to the sound.
How about the 27K (1W) resistor attached to the cathode of the output tube?
Mika
Reply #2 on: May 13, 2016, 10:01:30 AM
The 27K is bypassed with a large electrolytic, so the resistor has little effect. That cap will have more effect. The 75K and 10.5K in the RIAA filter are probably important. We have used good quality metal film resistors, so effects will be small.
Offline mwaller
Reply #3 on: May 16, 2016, 01:13:31 PM
Thanks for the reply!  Regarding that 100uF /160V bypass cap - what voltage rating is actually required in this application?  Is a 50V cap ok, or do you really need the 160V rating?
Mika
Online Doc B.
Reply #4 on: May 16, 2016, 01:31:49 PM
I'll suggest studying the schematic if you are going to make these modifications. From the schematic you can see that the voltage at the cathode of the 6922 is 27174 ohms x .0038A = 103V.
« Last Edit: May 16, 2016, 01:50:00 PM by Doc B. »
Offline mwaller
Reply #5 on: May 16, 2016, 01:52:16 PM
Thanks for the explanation. I'll have a closer look.
Mika
Offline mwaller
Reply #6 on: May 16, 2016, 04:22:30 PM
What brand / type is the stock 100uF 160v cap?  Mine doesn't have any mfg markings.  Thanks!
Mika
Online Doc B.
Reply #7 on: May 16, 2016, 04:26:29 PM
We use Nichicons.
