Just completed Crack Build,but have a few questions
robertone1 · 1596
Offline robertone1
Hi,just finished my Crack build on the weekend and in the process of burning in the tubes etc,so I can get onto installing the SpeedBall after some time.
This is one sweat sounding amp right of the bat on my Sen's HD650's.If this is how it sounds like now,can't wait to install Speedball and try some tube rolling.
First question I have is regarding voltages on a couple of terminals(mains voltage is 240V). Terminal 9 and B6 are a bit higher than the 10-15% rule.
Amp sounds great so far(also have M'Caps EVO on output).
Other question is how hot should this amp get?
Took some temp readings around amp and in some places its quite hot.Im thinking I should of painted the case plate in high temp paint,I can still smell the metal paint
I used venting off.
Resistance checks were right on the money.
12AU7 tube           131 F
6080 base of tube 125 F
6080 top of tube   203 F
Power trans top     116 F
Case top front        107 F
3K ohm Resistors  one 154 F the other 100 F (why the difference in temp from one to the other?)
220uf 250V connected to 14U   136 F
220uf 250V connected to 13U    112 F
220uf 250V connected to 20u     89 F
5W resistor                                  132 F
Terminal   Voltage    Actual
1                75-90     90
2                170        169
3                 0            0
4                170        168
5                75-90     101
6                0             0
7                100         112
8                0             0
9                100         119   (slightly higher than the 10-15%) rule
10              0             0
11              0             0
12              0             0
13              170         166
14              0              0
15              185          191
20              0              0
21              206          214
A1             90             100
A2             0                0
A4             0                0
A5             0                0
A6             90              88
A7             0                0
A9             0                0
B1             90              88
B2             170            169
B3             100            112
B4             90              100
B5             170            168
B6             100            119     (slighty higher again than 10-15%)
B7              0               0
B8              0               0
Will post some pics when I get around to paint the woodbase.
Thanks.
Reply #1 on: May 17, 2016, 05:11:19 AM
One triode of the 12AU7 is running a little bit high voltage on the plate, but it is nothing to worry about. Temps are fine.
