Crack got noise when connect the braided wire to volume control
ko853 · 1676
Offline ko853
Hi! My new crack got noise when I connect the braided wire from input jacks to volume control. Noise appears at 50% volume and louder at higher volume. If I touch the braided wire by hand, the noise will be louder. But if I disconnect braided wire from volume control, the crack will be dead silent even max volume.
Note: the crack (got speed ball) is not grounded and not connected to DAC yet. Headphone is HD650.
If I connect braided wire to volume control and grounding the crack, it will be dead silent in any case.
what I want to ask is why braided wire from input jacks to volume control can generate noise or I got mistake while building the crack?
Thanks.
« Last Edit: June 05, 2016, 07:43:19 AM by ko853 »
You should do a search on "Shorting plugs" and read the Crack FAQ, specifically item number 5: http://bottlehead.com/smf/index.php?topic=4295.0
An open input will pick up some ambient noise, so in order to draw any useful conclusions, you will need to use shorting plugs on the RCA jacks.
