Speaker selector switch
Bigskyguy1976 · 2676
Offline Bigskyguy1976
on: June 13, 2016, 04:18:59 AM
Hello y'all. I'm pretty new to the audiophile and high end audio equipment. It's been fun learning and assembling a system. I have a question to those deeper into it than me. I live in a log home and I really try hard not to display "plastic-y" electronic equipment. It doesn't doesn't go well with the home. Which is one of the reasons I came here to Bottle head. I love the wood, metal and tubes. I'm running IFi Retro 50 Amplifier, audiowood big easy turntable and I have a Bottlehead ETHOS Phono Pre-amp which I still need to build, Fern and Roby heartwood speakers. I really want the option of switching speakers A and B, with B speakers being outdoor speakers for the deck and patio.
Anyone know of a selector switch that is built with form as well as function without looking like a black plastic box? I don't think bottlehead builds one.
Offline borism
Reply #1 on: June 13, 2016, 05:51:19 AM
While I am sure there are commercial speaker selector switches available, here is a thread about DIY amplifier selector switches (2 amplifiers and one pair of speakers):
http://bottlehead.com/smf/index.php?topic=7476.0
I believe the same kind of switch can be used in reverse direction as a speaker selector.
Good luck!
Boris
Offline STURMJ
Reply #2 on: June 21, 2016, 05:29:20 AM
A Hammond diecast aluminum project box. A 4 pole double throw switch. Speaker binding posts of your choice (6 pairs are needed).
The diecast aluminum is soft enough that it can be drilled easily enough with a hand drill and standard bits, and it takes spray paint well. I made one with with a 8"x6" (I think most of the boxes they make are 4" tall, which is just right for pairs of binding posts) and that was the right size for me. I made a smaller one and that one got bullied around by the weight of the cables, and there was not enough room for all the connectors.
I like a big beefy toggle switch on the top side of the box. And since this is handling the power from the amps, you want a high amperage rated one ( Mine is 20A I think, and this is also where the beefiness comes from. not to mention the contact area will also be much larger than lower amp rated switches) If you cant figure out how to wire it, use your multi-meter to figure out what goes where. You might think this would be the most expensive part of the project but its not. (a quick search gave me a 15A switch for $5)
Then all you need is to install the binding posts, and solder in the wire (again this is fairly high power so use heavy wire) I like 4 pairs on one side of the box (for you, for each pair of speakers) and 2 pairs on the other ( for you the amp)
I have two of these in use in my system. I have a AV receiver for movies (with satellite speakers) and a Bottlehead system for music. I switch the L/R channel speakers to which ever system I am using. The other is a much smaller one for the sub-woofer. Since this is line level and not amp output level, I used a small switch, and obviously RCA connectors instad of binding posts.
