Simple question Regarding Part 10 Step 1,Passive RIAA
undertowogt · 19345
Offline undertowogt
Hi
I am close to being done my first build, almost there except for 1 question (hopefully)
I have a Simple question Regarding Part 10 Step 1,Passive RIAA. The instructions state...
Quote " Slip a 1-14" piece of teflon tubing over one lead of a Megohm resistor (1004F)."
The current kti does not come with Teflton, was this the old way of doing it in a past kit? Did they forget to add a revision on the revision page I was sent (with other instruction revisions).
I have teflon tape I used to make DIY cables a while ago, woudl that work?
Any thoughts?
Thanks in advance for the replys.
RT
« Last Edit: July 27, 2010, 12:13:22 PM by undertowogt »
Reply #1 on: July 27, 2010, 12:35:04 PM
you don't really need the teflon, so we no longer include it.
Offline undertowogt
Reply #2 on: July 27, 2010, 12:40:32 PM
Thanks for the reply. I guess I will trust your judgement Doc :)
BTW the kit is great
Reply #3 on: July 27, 2010, 07:21:53 PM
You can use a piece of wire jacket from the supplied teflon coated wire.
Offline undertowogt
Reply #4 on: July 28, 2010, 12:08:12 AM
I was thinking of that too. I wasnt sure if the outer (black)
 casing was teflon though. i guess it is
