Mainline BIAS Issue
Mike V. · 8253
Offline Mike V.
on: June 30, 2016, 08:03:45 PM
Hi guys, long time no chat, Finally I´ve dicided to build my Mainline kit that I bought in Dec'14. I have completed the kit, all messurements were correct, the 275V is 300V in my Reading. the rest of ohms and volts are perfect.
The issue I got is adjusting the BIAS of the A side. The B side I set it at 145V, but the A side is stucked at 80V if I rotate the switch I can get up to 81 or down to 74V until I start listening a click every turn I do. I switched the tubes and I was able to set BIAS at the B side at 145V, but The up I could get on the A side with the other tuve was 97V.
I have inspected all the soldering joints, and look fine, all leds are lighting. the only issue I guess I have is one Capacitor ZU5 that I solded it to close to its body.
Please help me!
« Last Edit: July 03, 2016, 02:51:16 PM by Mike V. »
Crack w/Speedball/HD650/DacMagic-100/
Mainline (on the way)/K702/ProJect Xpression III Classic w/ DL-103R/ Speedbox/Cambridge Audio 651p/
Reply #1 on: July 01, 2016, 07:06:20 AM
OB on the center board is the adjustable bias voltage for the A side.  What voltage do you have on OB at each end of the trimmer pot rotation?
Offline Mike V.
Reply #2 on: July 01, 2016, 07:55:09 AM
Sorry the side that I don't get the correct bias is the one of the C socket.
The OA measurements are the following: 3.7v - 0.69v
« Last Edit: July 01, 2016, 08:03:30 AM by Mike V. »
Offline Mike V.
Reply #3 on: July 02, 2016, 06:57:52 AM
I already re heat and solder all the C side, I get the same 97v
Offline Mike V.
Reply #4 on: July 02, 2016, 12:43:03 PM
I have checked and compare all voltages from both C4S boards, and all are equal except the one related to the bias 145v - 96v. I guess that will take me to the tube socket and after I have resolder everything, maybe the problems is with a ZU5 or a 1/8w resistor that I have blown  or is defective?
« Last Edit: July 02, 2016, 01:36:03 PM by Mike V. »
Offline Mike V.
Reply #5 on: July 04, 2016, 08:05:48 AM
Paul,
any thoughts on where might be the issue?
Reply #6 on: July 05, 2016, 08:19:10 AM
Can you verify that the resistance across the trim pot is actually changing when you turn the trim screw?
Offline Mike V.
Reply #7 on: July 05, 2016, 08:46:56 AM
Doc, How can I do that, do I messure the ohms from one leg of the trim to an other? the amp needs to be turn on?
Reply #8 on: July 05, 2016, 08:49:38 AM
Yes, from one end pin to the other end pin on the pot. Power off and amp unplugged as you are measuring resistance, not voltage.
Reply #9 on: July 05, 2016, 08:53:33 AM
Photos would be helpful at this point.  Can you confirm that you get the same adjustable range of voltages (approximately) from OB and OA on the center PC board?
If so, but your plate voltage won't move, this suggests a miswire or shorted connections, most likely on the bottom of the high current C4S board on the offending side.
Offline Mike V.
Reply #10 on: July 05, 2016, 10:39:35 AM
Doc, The resistance values are from 1 ohm to 2kohm
Offline Mike V.
Reply #11 on: July 05, 2016, 10:54:52 AM
These are the 3 boards
Reply #12 on: July 05, 2016, 11:02:42 AM
Could you send a pic of the underside of the middle board?
Offline Mike V.
Reply #13 on: July 05, 2016, 11:09:49 AM
Offline Mike V.
Reply #14 on: July 05, 2016, 11:21:55 AM
Yes I get the same. Tonight I will check the C4S board and check if everything is soldered as the manual.
« Last Edit: July 05, 2016, 11:46:38 AM by Mike V. »
