CRACK OTL - Issues After First POWER ON [resolved]
mipheres · 8595
Reply #30 on: November 03, 2016, 06:12:18 AM
Based on your voltages, at least half of the 12AU7 is glowing.  It can't be that both halves don't glow.  Please recheck with the light off in the room.
Also, can you measure (carefully) the DC voltage at A7?
Offline mipheres
Reply #31 on: November 10, 2016, 03:56:05 AM
Hi,
DC Voltage on A7 is 0 - zero.
Reply #32 on: November 10, 2016, 04:30:51 AM
Based on your voltages, at least half of the 12AU7 is glowing.  It can't be that both halves don't glow.  Please recheck with the lights off in the room.
Offline mipheres
Reply #33 on: November 14, 2016, 08:17:19 AM
yes, looks like both halves glow.
see attached
Reply #34 on: November 18, 2016, 06:39:19 AM
Carefully check the voltage at A8.
Offline mipheres
Reply #35 on: November 19, 2016, 08:19:25 PM
A8 measures 11.3V
Offline mipheres
Reply #36 on: November 25, 2016, 10:35:39 PM
Bump
Reply #37 on: November 26, 2016, 11:00:56 AM
You can replace the LED or wire in a jumper from A3 to A8.  (The LED has likely taken too much heat and has fractured)
Offline mipheres
Reply #38 on: November 26, 2016, 09:04:20 PM
sorry I dont know what to do exactly. can you write a more detailed explanation?
Reply #39 on: December 01, 2016, 01:14:34 PM
Connect A3 and A8 with a piece of wire.
Offline mipheres
Reply #40 on: December 04, 2016, 08:04:00 PM
Hi,
Looks much better now.
all measurements are around the documentation values:
where it says 90V in the document I measured 82V
where it says 170V in the document I measured 162V
Also at the TRS Peak test, I measured 10V and the decline was to 0V.
Do you think I can connect the HD650?
Best regards,
YM
Reply #41 on: December 08, 2016, 10:52:34 AM
Yes, I think you're ready to go.
