CRACK OTL - Issues After First POWER ON [resolved]
mipheres · 8150
Reply #15 on: September 28, 2016, 08:26:59 PM
Check your solder joint that connects A4 and A5.
Offline mipheres
Reply #16 on: October 01, 2016, 10:14:34 PM
Hi,
As you can see A4-A5 are ok.
the reading from Terminals:
1-140v
2-160v
3-0
4-160v
5-80v
Also, the second led does not glow.
Reply #17 on: October 02, 2016, 06:32:48 AM
Inside the 12AU7 are two vertical plate structures.  Can you see little glowing dots and the top and/or bottom of each of these structures while the amp is running?
Offline mipheres
Reply #18 on: October 06, 2016, 04:36:49 AM
no , I dont see the small tube glow.
The bigger tube is working.
Offline Deluk
Reply #19 on: October 07, 2016, 01:40:19 AM
Make sure the unlit led is soldered to the central pin. It looks a bit suspect there. Small tube glow varies. Some hardly glow at all and only show when its dark.
Offline mipheres
Reply #20 on: October 18, 2016, 08:11:12 PM
Hi I made sure the led is soldered ok.
Still same result,
the voltage measurements are off
small tube does not glow
one of the leds does not lit.
Offline Deluk
Reply #21 on: October 19, 2016, 01:53:49 AM
Looks as if you have a link between A1 and A2. This shouldn't be there.
Offline mipheres
Reply #22 on: October 30, 2016, 09:51:22 PM
triple checked A1-A2 connection, Nothing there: A1 is not connected to A2.
What should I check next?
Offline Deluk
Reply #23 on: October 31, 2016, 02:30:52 AM
Just looked at your picture again and have to say that I'm very surprised at that. What do others think?
Offline kgoss
Reply #24 on: October 31, 2016, 03:25:27 AM
The picture looks like maybe a resistor lead that you clipped is shorting the pins?  The wire looks a lot smaller than the coated wire.
Ken Goss
Offline ALL212
Reply #26 on: October 31, 2016, 11:23:12 AM
Witch LED are you referring too?
Offline borism
Reply #27 on: October 31, 2016, 12:44:27 PM
Of the WEST!
Boris
Offline ALL212
Reply #28 on: November 01, 2016, 01:23:37 PM
Since I'm feeling guilty about derailing this a bit...
I've blown boards and "other" with cutoffs falling into places you really don't want them to fall.  Based on the picture you may have a cutoff that has dropped into the socket area.  Toothbrush works good for sweeping in areas like that.  I have to use a magnifying glass to get in that close but it works.
Aaron Luebke
Offline mipheres
Reply #29 on: November 02, 2016, 09:07:38 PM
you are right about the clipping, but when I wrote "triple check", this was after  I cleared the metal and checked for a short with a tester.
witch way to go now? "go west"? ;D
