Speedball Upgrade. 2 LEDs are off = D1 Diode was not functional. [resolved]
ideal.hat · 8448
Offline Deluk
Reply #15 on: November 25, 2016, 12:54:12 PM
Great, thank you. I have places an order for 4x of those.
The eBay sale is for 5 off led for £3.30 so if you have ordered 4 you will end up with 20 and it will have cost you about 4 x the money. It confused me too but it does say 5x in the description. Should keep you going for a while.
Reply #16 on: November 25, 2016, 02:32:01 PM
What are ALL of the voltages specified in the manual?
Online Paul Birkeland
Reply #17 on: November 26, 2016, 10:54:50 AM
I would also be interested in the voltages at A7 and A8.
You can temporarily disconnect the wires to T1 and T2, then put the 22.1K resistor back in place.  Does this resolve your issue?  (I suspect it will not)
Offline ideal.hat
Reply #18 on: November 27, 2016, 03:53:20 AM
The readings are the following, I did them again to respond to you.
I notice an different reading on OA. See below.
OA= -0.2 to -0.4 (Problem) Expected=60-90v
IA= 179,4(OK) Expected=170-270V
B-A/B= 0V (OK) Expected=0V
IB= 179,4V (OK) Expected=170-270V
OB= 74,4 (OK) Expected=60-90V
Source= Page 19 in the Speedball 1.1 Manual
Gudmundur Asgeirsson
Bottlehead experience 4 out of 10.
I work as an IT administrator
Offline ideal.hat
Reply #19 on: November 27, 2016, 04:08:06 AM
I have been back and forth in  the manuals and I cannot terminal T1 and T2. Can you please describe them a little so I can locate them?
Could it be that T1 and T2 do not excist in my build since I have version 1.1 of the Speedball?
"then put the 22.1K resistor back in place"
I believe you mean both 22.1K resistors. I will "rollback" the speedball update and report back.
Here are fresh measurements.
Crack:
A1= -0.3
A2= *
A3= 0
A4= *
A5= *
A6= 0
A7= 55,6
A8= 0 (Nothing is connected to this terminal)
Speedball v1.1 = "Small Circuit Board"
« Last Edit: November 27, 2016, 04:13:43 AM by elgringo81 »
Offline ideal.hat
Reply #20 on: November 27, 2016, 04:25:48 AM
Crack:
A1= -0.3
A2= *
A3= 0
A4= *
A5= *
A6= 0
A7= 55,6
"I believe you mean both 22.1K resistors. I will "rollback" the speedball update and report back."
I can unfortunately not do the Speedball rollback because I have just broken one of the 22,4K resistors. :(
Reply #21 on: November 27, 2016, 05:35:57 AM
T1 is terminal 1. T2 is terminal 2. So on and soforth theough T22.
Offline diynewbie
Reply #22 on: November 27, 2016, 10:27:53 AM
It might be best to let those familiar with the new set-up give advice.  But since others have chimed in ....
I believe you have been requested to disconnect the input and output leads on the photo left side of the speedball  board at terminals 1 and 2 (T1 & T2 in the old manual refers to the lowest terminal strip which is attached to the nine-pin socket (transformer at top).
Then replace the 22.1k resistor on the left side only, across T1 & T2 or (1U and 2U may be used in the manual to refer to T1 & T2).
In effect, the right side in your photo would run thru the speedball while the left side would be the stock set-up.
Reply #23 on: November 27, 2016, 02:54:57 PM
Crack:
A1= -0.3
A2= *
A3= 0
A4= *
A5= *
A6= 0
A7= 55,6
Well, there should be an LED connected to A8.  When you get the *, you may need to increase the range on your meter to read the voltage properly.  I'm now very interested in what the actual voltage is at A2.
-Paul
Offline ideal.hat
Reply #24 on: November 28, 2016, 08:08:23 AM
Just to recap the current situation.
1. The Crack was working perfectly before I started on the speedball version 1.1 upgrade
2. I have only completed installing the Speedball 1.1 (small circuit board(Formerly v. 1.0, I believe it was two separate boards))
3. I am currently on page 19 in the Speedball 1.1 manual. On that page I have to do measurement and it is there where I have my problem.
    Terminal AO gives me a bad value = -0,2V so I will not go further in the manual until I have resolved this or someone tells me otherwise :)
I just made the following measurements
Crack:
T1=-0,8
T2=179,8
T3=0
T4=180,2
T5=0
T6=0
T7=56,9
T8=0
T9=103
T10=0
T11=0
T12=0
T13=179,4
T14=0
T15=195,7
T16=0
T17=8,85
T18=80,1
T19=80
T20=0
T21=212
T22=0
A1=75,3
A2=0
A3=1,55
A4=0
A5=0
A6=-0,06
A7=0
A8=0,96
A9=-0,05
B1=-0,98
B2=178,5
B3=56,7
B4=75,2
B5=178,8
B6=102,9
B7=0
B8=0
OA= -0.2 to -0.4
IA= 179,8
B-A/B= 0
IB= 179,7
OB= 74,8
Offline ideal.hat
Reply #25 on: November 30, 2016, 08:53:40 AM
-Paul
That is correct. the LED is connected to A8.
A8 measures = 0,96
A2 Measures = 0
See full list of measurements above.
Reply #26 on: December 01, 2016, 12:53:54 PM
Can you swap the connections at OA and OB?  You may have to tack on a temporary jumper to make these reach, but this will tells us if the problem is on the board or on the amplifier.
Offline ideal.hat
Reply #27 on: December 02, 2016, 08:43:02 AM
I have done as you suggested and here are the results.
There were few things that I noticed after swapping OA and OB.
When OA and OB are connected normally, LED A3 is ON but LED A8 is OFF.
When I swap OA and OB. LED A8 is ON but A3 is OFF.
LED D1 on Board A is OFF, before and after swapping.
There is a slight reading difference on OA.
Readings OA/OB swapped
OA= -0,06
IA= 182,4
B-A/B= 0V
IB= 182,2V
OB= 74,8
Readings  OA/OB no swap
OA= -0.2 to -0.4
IA= 179,8
B-A/B= 0
IB= 179,7
OB= 74,8
Offline ideal.hat
Reply #28 on: December 06, 2016, 03:43:31 AM
I am still dealing with this and my Crack is nothing more than a beautiful table decoration at the moment:(
Can somebody please help me, I would be ever so grateful.
Offline diynewbie
Reply #29 on: December 08, 2016, 02:37:58 AM
I'll bump this for you.
My guess would be something wrong on the A board.  The suggestion above of disconnecting the A side from T1/1U, T2/2U and replacing the 22.1k resistor across those terminals should confirm this.  I would expect both socket LEDs to light up and better voltages at A6, B1 and B3.  I would suspect the D1 diode or 2N2907 transistor.  Since you wrote that new diodes were ordered, you might want to try replacing that diode if re-flowing the joints on those two components doesn't/didn't fix the issue.  BUT, I know very little about electronics.
Best would be if someone who knows something about this stuff answered this thread.
« Last Edit: December 08, 2016, 02:49:58 AM by diynewbie »
