Speedball Upgrade. 2 LEDs are off = D1 Diode was not functional. [resolved]
ideal.hat · 8450
Reply #30 on: December 08, 2016, 10:20:57 AM
Yes, there is an issue either with the small PC board, or with the wires that connect it to your Crack.  If all else fails, you can contact replacementparts(at)bottlhead(dot)com regarding a replacement PCB.b
Offline ideal.hat
Reply #31 on: December 09, 2016, 03:15:36 AM
Thanks for the bump and feedback.
I will give this a close look over the weekend and report back.
Gudmundur Asgeirsson
Bottlehead experience 4 out of 10.
I work as an IT administrator
Offline ideal.hat
Reply #32 on: December 11, 2016, 03:40:06 AM
I'll bump this for you.
My guess would be something wrong on the A board.  The suggestion above of disconnecting the A side from T1/1U, T2/2U and replacing the 22.1k resistor across those terminals should confirm this.  I would expect both socket LEDs to light up and better voltages at A6, B1 and B3.  I would suspect the D1 diode or 2N2907 transistor.  Since you wrote that new diodes were ordered, you might want to try replacing that diode if re-flowing the joints on those two components doesn't/didn't fix the issue.  BUT, I know very little about electronics.
Best would be if someone who knows something about this stuff answered this thread.
SOLVED!! the problem was the D1 diode, thanks for the tip ;)
Offline ideal.hat
Reply #33 on: December 11, 2016, 03:44:13 AM
Finally, me issue has now been resolved, thanks to this great community here.
For those interested, I attach some pictures of my Crack setup.
... This is going to be a great Sunday :)
Offline kgoss
Reply #34 on: December 11, 2016, 04:14:54 AM
I really like the combination of the black paint and the finish you did on the base.
Nice job. Enjoy!!!
Ken Goss
Offline ideal.hat
Reply #35 on: December 11, 2016, 04:55:32 AM
Nice job. Enjoy!!!
Thank you, The credit goes to my dad.. He helped me with the woodwork this summer when I was visiting him in Iceland.
He is a well skilled handcrafts man.
Offline Deluk
Out of interest, did you use one of the eBay LED's as replacement for your u/s one? Would be good to know if they are correct as I have added some to my spares box. Thanks.
Offline ideal.hat
Deluk: I bought these as spares. Doc said they were the correct ones. £3.30 + £1.99 to Dk.
http://www.ebay.co.uk/itm/5-X-LED-SUBMIN-RED-Part-HLMP-6000-/351609648339?hash=item51dd9174d3:g:HvYAAOxyd8NSa78D
ElGringo81: Yes correct. I did and they work perfectly. Thank for pointing me in the right direction there :)
Offline Deluk
Thanks for the confirmation, good to know that there is currently a European source at a not unreasonable price. I have to fit my Speedball yet, probably over the Christmas period, but would rather not have to replace any of them on those boards either.
