Errors in manual? - Crack chassis assembly done but with one spare #6 lockwasher
cddc · 2501
Offline cddc
Just finished assembled the Crack chassis. But found I was left with one #6 lockwasher unused.
I double checked the manual, and really couldn't find where it should go.
There are two #6 lockwashers in total. One of them goes to the front hole for the nine-pin socket. But where should the 2nd #6 lockwasher go?
Is it possible that there's an error in the Crack manual, or the left-over #6 lockwasher will be used later in the speedball upgrade (which has not been done yet)?
Really appreciate it if anyone could help.
2 are used. Which crack version do you have?
Offline cddc
Thank you very much for your kind answer.
Where are the two #6 lockwashers used?
I can only see one of them is used in the front hole for the 9-pin socket on Page 13. Really don't know where the 2nd #6 lockwasher should go.
The front page of my Crack manual says "revised December 17, 2013...copyright 2010" .
The front page of my Speedball manual says "Speedball 1.1 manual...copyright 2015"
Offline cddc
My Crack is the 120V only version, which I bought at the beginning of this year. Just started to assemble it this weekend.
So it's not the new universal 120/240V version.
It should go between the 5-lug and the nut on the 9-pin socket.
Offline cddc
Great, thank you very much.
