Help identifying Bottlehead preamp & rectifier
iLikeSound · 13581
Offline iLikeSound
on: December 09, 2016, 07:31:38 AM
Hello all,
New here. At some point I'll buy and build a kit. In the meantime:
I recently bought (via craigslist) a Bottlehead preamp. Hoping you could help tell me which one it is (or if it's a FrankenHead). The small tubes are both 12au7.
I also can't identify the rectifier. The base says RCA Electron Tube, and has Made in USA, and 3-39. The internal parts look interesting to me: The upper and lower spacers are toothed, like a bike cog, and the plate is cylindrical. It glows blue.
Pictures below. Thanks in advance!
Offline Natural Sound
Reply #1 on: December 09, 2016, 07:46:28 AM
Thats a Foreplay III. The "regulator" is an 0D3, 150V regulator. The rectifiers are solid state. Does it work OK?
Offline iLikeSound
Reply #2 on: December 09, 2016, 07:56:57 AM
Thanks a lot - that was fast!
Yes, it works fine. Sometimes I need to wiggle the input cables a little to get one channel to work, but I'll clear that up as soon as I open it and check the solder connections.
Will changing the regulator (to a different brand, or a different type) affect the sound much (or at all)?
« Last Edit: December 09, 2016, 08:04:12 AM by iLikeSound »
Reply #3 on: December 09, 2016, 08:04:27 AM
I never found regulator tube rolling to have an effect on the sound.
Reply #4 on: December 09, 2016, 08:29:13 AM
It looks like it uses the basic Foreplay III circuit and probably one of our power transformers. But it's not a Foreplay III factory chassis. So yes, it is in some ways a Frankenstein.
