Crack working one minute - dead the next [Resolved]
mickp elijah audio · 2075
Offline mickp elijah audio
on: December 15, 2016, 02:31:09 AM
Hi all , first post and as a tube newbie, I will no doubt be returning for more help
I bought a standard Crack secondhand - and had to do a bit of resoldering to get the right channel working
I am blown away by the sound through my also recently purchased HD 650's
Tonight's issue (midnight , Adelaide , Sth. Aust)
Used the Crack last night, and switched it off when finished - went and turned it on tonight - DEAD - The fuse is OK
Any ideas why it would behave like this ??
Thanks for any help
Michael Parin
CEO Elijah Audio
« Last Edit: December 16, 2016, 09:39:07 AM by Caucasian Blackplate »
Michael Parin
CEO Elijah Audio
Offline Tom-s
Reply #1 on: December 15, 2016, 04:32:44 AM
Perform resistance and voltage checks.
Reply #2 on: December 15, 2016, 04:42:50 AM
Thanks, but I thought those checks were only performed to get a new Crack working
Mine has been working OK for 2 weeks and  now won't fire up
Does it mean something , e.g. the transformer, has died ??
Michael Parin
CEO Elijah Audio
Reply #3 on: December 15, 2016, 06:34:53 AM
If something was wrong with the transformer, it never would have worked in the first place. The odds of getting a bad transformer are essentialy zero. When we have had problems with transformers, the problem has been traced to improper installation damaging the transformer, and not a defect in the transformer.
Your problem is almost certainly a poor solder joint that has expanded and contracted with heat from being turned on and off. Resistance and voltage checks will help locate the problem.
Reply #4 on: December 15, 2016, 08:08:07 AM
Thanks - as I have already had to fix a few dud  solder joints - this is good news
I will report back ASAP
Thanks again
Michael Parin
CEO Elijah Audio
Reply #5 on: December 15, 2016, 08:13:29 AM
Check that the power switch contacts are actually closing with your DMM. Sometimes the switch is damaged when installed and makes intermittent contact.
Reply #6 on: December 15, 2016, 12:26:03 PM
Thanks to all - sweet music again
I reflowed a couple of joints on IEC socket  and also clipped a couple of bare wires that were very close to neighbouring wires
Not sure which one did the trick, but I am a happy camper once again  :)
Did you hear about the farmer that won the Nobel prize?
He was out standing in his field.............
Thanks again
Michael Parin
CEO Elijah Audio
