Speedball Voltage Check Issue [resolved]
M42 · 5529
Offline M42
on: January 05, 2017, 01:40:20 PM
I am installing the small board for the Speedball upgrade. All the led's are illuminated, but I am getting a low voltage reading at OB. The indicated voltage is 11.12 volts instead of the anticipated 60 to 90 volts. The other readings are as follows:
OA  =  69.5 v
1A  =  232 v
B-A/B  =  0 v
I have checked all my connections/solder joints and reheated what I thought might be suspect. I noticed that one of the led's on the nine pin socket was no longer illuminated (the one connected to A3 and the center terminal). Prior to the upgrade the amp always run dead silent, but during my last listening session with the amp I notice a low level hiss I'd not heard before. I'd forgotten about that before starting this project!
Would the failure of the socket led cause the voltage problems indicated at OB? I have done the chopstick test around the nine pin socket...the led does not light even intermittently. I know this issue should have been identified and dealt with in the first instance...my bad! Any advice would be appreciated.
« Last Edit: January 23, 2017, 08:55:00 AM by Caucasian Blackplate »
Jeff Hullin
Stereomour(2A3), Eros, Crack/Speedball, Thorens TD160 MKII, Grace F9E, Sennheiser HD600's, Frugelhorn 3's, DIY 8" Subs.
If at first, the idea is not absurd, then there is no hope for it.
Reply #1 on: January 05, 2017, 01:44:47 PM
You need to reheat all the solder joints on the MJE350 on the "B" side of that PCB, as the solder has not been allowed to flow properly.
Having used the chopstick test (intended to find noise issues usually), if you've poked the LED enough times, you can certainly break it.  If the LED is broken, OB voltage will be much higher than expected, and the voltage at A3 will settle to around 12V (and the LED will not be lit). Only if all three of these conditions are met should you consider the LED to be the issue.
(See page 20 in the manual for similar information)
Offline M42
Reply #2 on: January 05, 2017, 02:02:39 PM
Thanks for your reply Paul. I have reheated the MJE350 on the B side, the results are the same...I'm still getting 11 volts and the led on the tube socket does not light. The solder has wicked up around all three legs of the MJE350 from the bottom of the pcb.
Jeff Hullin
Reply #3 on: January 05, 2017, 02:06:30 PM
Pop each wire out of OA and OB, then twist the board 180 degrees and reattach the wire from 5 to OA and the wire from 1 to OB, then recheck your voltages.
Offline M42
Reply #4 on: January 05, 2017, 02:31:25 PM
The readings are now as follows:
OA  69.5v
1A  232v
B-A/B  0v
OB  69.9v
Jeff Hullin
Offline M42
Reply #5 on: January 05, 2017, 02:38:03 PM
I read the wrong column...OA reads 11v
Jeff Hullin
Offline Deluk
Reply #6 on: January 06, 2017, 01:59:32 AM
Is the white wire on the right side in the earlier picture properly attached to the tag strip? Insulation looks to just disappear into the hole.
Offline M42
Reply #7 on: January 06, 2017, 02:11:03 AM
I'm certain I have a good connection there. I'll reflow the joint again this evening. I failed to mention in the previous post that the led on the nine pin socket (at A3) still does not illuminate.
Jeff Hullin
Reply #8 on: January 06, 2017, 08:14:55 AM
That's good information.  When you flipped the board around and the low voltage changed from OB to OA, that tells us that the small PC board is working.
As to why the issue is occurring in the first place, some potential causes are debris in or around the tube socket causing a short between pin A6 and A7 (or A6 and A5), what DC resistance do you get from terminal 5 to ground?
Also, to reiterate again, this is a problem that has nothing to do with the LED that isn't lighting.  If the LED was shorted out, terminal 5 would read something like 50V, and if the LED was open it would read around 170V.
Offline M42
Reply #9 on: January 06, 2017, 12:45:48 PM
Measuring the resistance from the ground lug and terminal 5 the meter reads O.L the scale indicates M ohms. You will have to bear with me as the only reason I get these kits together are the outstanding build manuals. I know which end of the soldering iron gets hot....but beyond that............?
Jeff Hullin
Reply #10 on: January 06, 2017, 12:57:20 PM
How about the resistance between terminal 5 and A2?
Offline M42
Reply #11 on: January 06, 2017, 01:05:31 PM
With power off -2949 ohms
Jeff Hullin
Offline M42
Reply #12 on: January 06, 2017, 01:19:29 PM
Ground lug to T5 is 2966 ohms
Jeff Hullin
Reply #13 on: January 06, 2017, 02:47:03 PM
Yeah, now we are getting somewhere.  There are two 3,000 Ohm resistors in the amp, they connect to the 6080 back at the octal socket.  If, somehow, there is a miswire or a short back there, then sending a few mA of current through a 3,000 Ohm resistor will get you the weird voltage you have.
Did this Crack work before you put the Speedball in?
Offline M42
Reply #14 on: January 07, 2017, 07:28:49 AM
The amp has run without issue since I completed it about three years ago...it always ran dead silent. I had a chance to listen to it recently after it not being used for some time. It sounded great as usual, but as I was about to shut it off I did notice a low level hiss. I had not heard that before. I did not listen to it again before the upgrade kit arrived and forgot about it. As a result I didn't discover the led issue at the tube socket until then.
I have checked around the tube socket and find no debris which might be contributing to this problem.
Jeff Hullin
