Bottlehead Kits
Crack
Adding RCA outputs
Adding RCA outputs
currly30
1758
currly30
Full Member
Adding RCA outputs
January 05, 2017, 02:48:02 PM
Hello everyone!
I want to try adding RCA out puts to my crack, so I can get that sweet tube sound on any of my devices.
I have all the equipment to add new mounts to the chassis and have spare RCA jacks. So there is no worries about that.
My main questions are:
Is possible to add the RCA so that they are out putting pre-amp, passive, so I wont end up amping an amp?
If I am able to add passive RCAs how would I wire them in?
If I'm able to add the passive RCAs would I have to add a switch to turn them on and off to make sure that they don't act as a voltage sink?
If I'm not able to add the RCAs before the amp would I be able to just piggy back them into the headphone out or would I have to add a switch to change between them?
currly30[/list]
Last Edit: January 05, 2017, 02:57:17 PM by currly30
Doc B.
Administrator
Hero Member
Re: Adding RCA outputs
Reply #1 on:
January 05, 2017, 05:08:09 PM
You're making it more complicated than it needs to be. Just get a TRS to dual RCA adapter and plug it in the headphone output. That is the most logical way to use the Crack as a preamp.
Bottlehead Kits
Crack
Adding RCA outputs
